查看: 2423|回复: 0
[资料] 大相对孔径大视场紫外告警相机光学系统
发表于 2015-7-10 16:43:34 | 显示全部楼层 |阅读模式
大相对孔径大视场紫外告警相机光学系统
Optical system for ultraviolet warning camera with wide field of view and large relative aperture
下载全文
大相对孔径大视场紫外告警相机光学系统.pdf (286.29 KB, 下载次数: 6)
作  者:王红
WANG Hong (Key Laboratory of Optical System Advanced Manufacturing Technology, Changchun Institute of Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changchun 130033,China)
机构地区:中国科学院长春光学精密机械-9物理研究所中国科学院光学系统先进制造技术重点实验室,吉林长春130033
出  处:《光学精密工程》 EI CSCD 2014年第22卷第12期 3212-3216页,共5页
Optics and Precision Engineering
基  金:国家自然科学基金资助项目(No.60507003)
摘  要:为了满足紫外告警相机的特殊应用需求,分析了超广角光学系统的结构形式、像差平衡以及像面照度的一致性。设计了工作于0.254~0.272m波段的大视场、大相对孔径紫外光学系统,其视场角为120°,相对孔径为1/2。该系统采用反远距,准像方远心光路设计,减小了轴外视场和轴上视场的像面不均匀性;通过优选光学材料并合理分配光焦度优化了系统特性。实验显示,该系统在满足成像质量要求的前提下,具有成像畸变小、像面照度均匀等特点。光学系统全视场最大弥散斑半径小于63.5m,轴上、轴外视场像面照度均匀性小于10%,0.71视场的相对畸变小于20%。整个光学系统结构紧凑,满足设计指标要求,适合紫外告警相机的使用。
For the special use demands of ultraviolet warning cameras,the structures,distortion balances and the consistency of image plane illumination of ultra wide-angle optical systems were analyzed.An ultraviolet optical system with a large field of view of 120°and a large relative aperture of1/2was designed.The system is a double imaging configuration with the spectral range from 0.254 m to 0.272 m.By using inverse telephoto structure,its back working length is 7.48 mm.A quasi-telecentric optical system was selected to improve the illumination uniformity for off-axis and on-axis view fields.Then,by choosing optical materials and distributing the focal powers reasonably,the optical system was optimized.The experiments demonstrate that the system is characterized by smaller imaging distortion and uniform image plane illumination,the dispersion spot diameter is smaller than63.5m,and the relative distortion at 0.71 field of view,the relative illumination uniformity for offaxis and on-axis view fields are less than 20% and 10%,respectively.The structure of the whole sys-tem is compact and feasible,and is suitable for ultraviolet warning cameras.
关键词:光学设计 大视场大相对孔径相机 紫外告警 反远距 像面照度
optical design ; space camera with wide angle and large relative aperture ; ultraviolet warning ; inverse telephoto ; image plane illumination ;
