悬赏问答
3回答 2626查看
悬赏 元光电贝
  提问于 2005-8-31 06:03:00
有美国SYNRAD CO2 激光器便宜卖 型号:F100,最大功率:100w, 2005年10月到货, 联系人:wuhanyhcn@126.com The firestar f100 features: 100 watt CO2 laser Excellent Beam Quality Integrated RF Water Cooled Small Footprint, Compact Design Ruggedized, 3-point Mounting System The firestar f100 is constructed around the basic building block of all f-series lasers, Synrad’s patented, compact free-space resonator tube. Together with the f-series’ innovative integrated on-board RF drive system, the f100 represents the industry’s smallest fully RF integrated 100 watt laser solution. The firestar f100’s patented tube design creates a laser that is only 25.1inches in length and operates from a single low-cost 96 VDC power supply. In applications such as production line high-speed parts marking where space constraints can be a key project requirement, the f100 is a perfect fit. firestar f -series 100 Watt Specifications: Output Power100W Mode QualityTEM00, 95% Purity M²<1.2 Ellipticity<1.2 Rise Time<150µsec Beam Diameter3.5mm Beam Divergence (full angle)4.0mR Wavelength10.2-10.7µm Power Stability: cold start (guaranteed): after 2 minutes (typical):±10% ±6% PolarizationLinear (Horizontal) CoolingWater Heat Load (max)2000W Flow Rate (18-22°C)2.0 GPM, <60PSI Input Voltage / Current96 VDC / 18A Dimensions, laser head (in)25.1 x 6.3 x 5.6 (mm) 638 x 160 x 142 Weight38 lbs / 17.2 kg
主题回复
倒序浏览
2626查看3回复
2005-9-1 01:23:00
老大,卖给大陆人也该翻译成中文吧,最好是简体得。
举报 回复
2005-9-2 01:25:00
便宜卖是多少钱嘛!总的让大家看看哈
举报 回复
2005-9-2 22:12:00
呵呵,楼主,我知道你是谁了,3楼的大胖子,:)
举报 回复
