[分享]特种,精密零部件和模具加工(Special, precision parts and tools machining)
2.7k 0
发表于 2005-9-6 18:35:00|江苏 | 查看全部 阅读模式
为您排忧解难、节省时间、节省成本是我的最大心愿,我能为阁下解决以下技术难题.
Eliminating your worries and difficulties, saving your time and costs are my supreme wishes. Here, I would like to inform you that I can solve the following difficult technical problems for you.
★ 超微超深细孔加工:可在金属上加工0.1mm以上的细孔,深度达到3mm.
Manufacture capability of ultra-fine and ultra-deep for small bores: can machine holes with dia over 0.1mm, depth 3mm.
★     五轴连动加工(瑞士米克朗)
5-axis continuum machining(Switzerland MIKRON)
★ 超细电极慢走丝线切割:瑞士阿奇夏米尔线切割,最细电极丝达到0.03mm,可进行超高光洁度(达到0.1μ),超细清角(最小尖角达到0.025mm)线切割加工.
Ultra thin slow wire-cutting: Switzerland Agie Charmilles wire-cut, withthe thinnest 0.03mm, also capable of machining ultra-fine finish (0.1μ) and ultra-sharp angle (smallest 0.025mm).
★ 钨钢(硬质合金)成形加工:钨钢成型磨削、外园磨削.
Tungsten steel (hard alloy) forming machining: tungsten forming grinding,cylindrical grinding.
★ 超长孔加工:最小孔径0.3mmX50mm(超长),公差在0.002mm.
Ultra-long hole machining: smallest hole 0.3mmX50mm(super long), tolerance 0.002mm.
★ 精密外园磨削:超长、超细轴磨削,尺寸精度达到2μ,同轴跳动2μ以内.
Precision cylindrical grinding: ultra-long and ultra-thin axis grinding, with precision to 2μ,coaxial jumping within 2μ.
★ 精密内,外螺纹磨削加工.
Precision inner and outer thread grinding machining.
★     精密镜面抛光,超平平面抛光.
Precision mirror polishing. Ultra-flat surface polishing.
有任何问题请随时联系我
Any questions pls don’t hesitate to contact me.
Kind Regards
William Chen
太仓戴尔塔精密模具有限公司
TaiCang DELTA Precision Tools Co.,Ltd.
Tel:+86-512-55772599  53509141
Fax:+86-512-53560880
www.deltatools.cn
william@deltatools.cn
delta@126.com (big file)
