求助!
1.8k 2
发表于 2005-9-15 01:00:00|陕西 | 查看全部 阅读模式
欲购买3800nm的小型激光器或二极管,请各位高人指条名路
回复|共 2 个
dcf1982 Lv.9 发表于 2005-9-15 07:52:00|湖北 | 查看全部
我也有同样的需求 是3到5um  只要能成象就可以 功率不是问题  我的邮箱dcf1982@126.com
Raytress Lv.9 发表于 2005-9-15 08:12:00|美国 | 查看全部
Laser diodes for spectral range 2.7-3.8 mm are mounted on LA-type open packages which are necessary to be placed in cooling system. Operating temperature range for our 2.7-3.8 mm Laser Diodes is 30-100 K in CW regime and 30-150 K in pulse regime. Using laser structures based on III-V solid solutions gives us many advantages in comparison with laser structures based on lead salts due to fundamental characteristics of III-V materials - higher power, higher spectral purity, higher reliability and longer life-time.
Earlier lasing frequency was usually tuned only by heating. Besides this quite slow process our tunable diode lasers for spectral range of 2.7÷3.8 mm providecurrent controlled wavelength shift about 0.5¸1.0 cm-1in single-mode lasingtowards the shorter wavelength based on nonlinear optical phenomena.
Laser diode Models in which super-fast current tuning is available are marked with letters “tun” - for example model LD331-tun-LA. Other models (for example LD331-LA) can be tuned by changing the temperature.We are also offering Laser Diodes mounted in a small dewar. In this case model is marked with letters “DW” – LD331-DW or LD331-tun-DW.Standard Models LDXXX-LA and LDXXX-tun-LA are made from narrow-stripe laser structures and have average power about 1 mW and single longitudinal mode structure (SLM) that means that at determinate current and temperature range main mode is stronger then common intensity of other modes.
              Ordering Information
MODELregimePackageCurrent tuningMode Pattern
LDXXX-LA
Pulsed, CWLAnoSLM, SM
LDXXX-DWPulsed, CWDewarnoSLM, SM
LDXXX-tun-LAPulsed, CWLAyesSLM
LDXXX-tun-DWPulsed, CWDewaryesSLM
