[讨论]CODE TOLERANCE 分析
2.4k 0
发表于 2007-4-8 07:54:00|云南 | 查看全部 阅读模式
<p> C O D E V POSITION 1</p><p> I N V E R S E S E N S I T I V I T Y<br/> POLYCHROMATIC MODULATION TRANSFER FUNCTION</p><p> Cooke Triplet f/4.5</p><p>-------------------------------------------------------------------------------------------------------------</p><p> WAVELENGTH WEIGHT NO. OF RAYS<br/> FIELD (X,Y) = ( 0.00, 0.00)MAX, ( 0.00, 0.00)DEG 656.3 NM 1 752<br/> FIELD WEIGHT = 1.00 546.1 NM 2 760<br/> 486.1 NM 1 776</p><p> FREQUENCY = 15.00 L/MM<br/> AZIMUTH = TANGENTIAL</p><p><br/> DIFFRACTION LIMITED MTF = 0.9466<br/> NOMINAL MTF = 0.8883</p><p>-------------------------------------------------------------------------------------------------------------<br/> MANUFACTURING ERROR CHANGES IN MTF FOR COMPENSATING PARAMETERS<br/> PLUS AND MINUS<br/> TYPE CHANGE MANUFACTURING ERRORS DLZ S7</p><p> DLF S1 2.0000000v -0.0006 0.0006 -0.037425<br/> DLF S2 2.0000000v 0.0017 -0.0018 0.038187<br/> DLF S3 2.0000000v 0.0061 -0.0065 -0.057692<br/> DLF S4 2.0000000v 0.0004 -0.0006 0.055081<br/> DLF S5 2.0000000v -0.0003 0.0003 -0.031846<br/> DLF S6 2.0000000v -0.0041 0.0040 0.029928<br/> DLR S1 0.0600000v 0.0028 -0.0040 0.218316<br/> DLR S2 0.4000000v -0.0020 0.0019 -0.042205<br/> DLR S3 0.0200000v -0.0066 0.0062 0.058360<br/> DLR S4 0.0800000v -0.0026 0.0005 -0.179352<br/> DLR S5 15.0000000v 0.0009 -0.0021 0.170823<br/> DLR S6 0.0200000v 0.0116 -0.0128 -0.089555<br/> DLT S1 0.0800000v 0.0087 -0.0094 -0.103813<br/> DLT S2 0.0200000v -0.0004 0.0002 -0.062695<br/> DLT S3 0.0200000v 0.0048 -0.0052 0.003073<br/> DLT S4 0.0200000v 0.0052 -0.0054 -0.011256<br/> DLT S5 0.0200000v 0.0034 -0.0035 -0.004987<br/> DLN S1 0.0005000v -0.0031 0.0028 -0.071990<br/> DLN S3 0.0010000v -0.0047 0.0042 0.162261<br/> DLN S5 0.0010000v 0.0082 -0.0089 -0.122481<br/> DLV S1 0.0080000v -0.0009 0.0006 -0.000355<br/> DLV S3 0.0080000v 0.0009 -0.0021 0.000768<br/> DLV S5 0.0080000v -0.0008 0.0006 -0.000370<br/> CYD S1 0.5000000v -0.0005 0.0000 -0.004489<br/> CYD S2 0.5000000v 0.0000 -0.0005 0.004769<br/> CYD S3 0.5000000v -0.0001 -0.0011 -0.007005<br/> CYD S4 0.5000000v -0.0002 -0.0007 0.006717<br/> CYD S5 0.5000000v -0.0002 -0.0001 -0.003980<br/> CYD S6 0.5000000v -0.0007 0.0004 0.003333<br/> CYN S1 0.5000000v 0.0053 -0.0057 -0.003973<br/> CYN S2 0.5000000v -0.0058 0.0054 0.004448<br/> CYN S3 0.5000000v 0.0091 -0.0103 -0.006463<br/> CYN S4 0.5000000v -0.0085 0.0077 0.006191<br/> CYN S5 0.5000000v 0.0049 -0.0052 -0.003572<br/> CYN S6 0.5000000v -0.0057 0.0053 0.002848<br/> TRY S1 0.0040000v -0.0001 -0.0001 0.000000<br/> TRX S1 0.0040000v 0.0000 0.0000 0.000000<br/> BTY S1..2 0.0003000v 0.0000 0.0000 0.000000<br/> BTX S1..2 0.0003000v 0.0000 0.0000 0.000000<br/> DSY S1..2 0.0200000v -0.0010 -0.0010 0.000000<br/> DSX S1..2 0.0200000v -0.0003 -0.0003 0.000000<br/> TRY S3 0.0020000v -0.0003 -0.0003 0.000000<br/> TRX S3 0.0020000v -0.0001 -0.0001 0.000000<br/> BTY S3..4 0.0003000v -0.0001 -0.0001 0.000000<br/> BTX S3..4 0.0003000v 0.0000 0.0000 0.000000<br/> DSY S3..4 0.0200000v -0.0175 -0.0175 0.000000<br/> DSX S3..4 0.0200000v -0.0065 -0.0065 0.000000<br/> TRY S5 0.0100000v -0.0007 -0.0007 0.000000<br/> TRX S5 0.0100000v -0.0002 -0.0002 0.000000<br/> BTY S5..6 0.0003000v -0.0001 -0.0001 0.000000<br/> BTX S5..6 0.0003000v 0.0000 0.0000 0.000000<br/> DSY S5..6 0.0200000v -0.0098 -0.0098 0.000000<br/> DSX S5..6 0.0200000v -0.0037 -0.0037 0.000000</p><p> PROBABLE CHANGE IN MTF -0.0445</p><p> PROBABLE CHANGE OF COMPENSATORS (+/-) 0.509843</p><p> Units - linear dimensions in mm. angles in radians,<br/> fringes in wavelengths at 546.1 nm.</p><p> The probable change and cumulative probability results are based on the<br/> assumption that the distribution of the MTF converges to a Gaussian form</p><p> CUMULATIVE CHANGE<br/> PROBABILITY IN MTF<br/> 50.0 PCT. -0.0099 * If it is assumed that the errors can<br/> 84.1 PCT. -0.0272 only take on the extreme values<br/> 97.7 PCT. -0.0445 * of the tolerances, the 97.7 percent<br/> 99.9 PCT. -0.0618 probable change in MTF is -0.0918</p><p> </p><p>我理解是Cooke Triplet f/4.5系统轴上,在上述允许公差范围内的情况下,在 FREQUENCY = 15.00 L/MM时,最坏的MTF与设计值将下降 -0.0918对吗?<br/><br/></p>
