外企光学公司招聘真空镀膜主管
4.7k 3
发表于 2007-7-12 20:36:57|广东 | 查看全部 阅读模式
Job description:
1.Provides technical support for vacuum coating; solves problems arising in production on time. Ensures production operators receive enough support when they need.
2.Monitors the process implemented correctly as required. Rectifies any wrong operations and processes. Stabilizes the process conditions.
3.Keeps improving process to achieve higher yield and production efficiency. And updates the relevant document on time.
4.Assists production people to improve the manufacturing environment and cost down.
5.Develops the raw & consumable material to improve the material property.
6.Assists to fix the equipment problems in the vacuum coating areas, to minimize the break down time.
7.Trains the operators on tech and make SOP understood completely by relevant operators.
8.Takes up ad-hoc projects as supervisor assigned.
Requirements
1.University graduate or above. Major in Engineering or related discipline.
2.Fluent in both written and spoken English, and can communicate with foreign colleagues.
3.Good team work spirit, positive and accountable.
4.Over 3 years experience in vacuum coating,
5.Familiar with process of vacuum coating and vacuum coating equipment
6.Experience in vacuum equipment maintenance and design is prefered.
工作地点:广州
有意者请将个人信息发至:xh3023@163.com
回复|共 3 个
hcatp812 Lv.6 发表于 2007-7-13 21:47:06|北京 | 查看全部
镀膜的公司很多都在广州啊
jumiel Lv.2 发表于 2007-7-14 17:22:50|湖北 | 查看全部
不知道有多少米,10K有没有
APS1104 Lv.7 发表于 2009-10-24 21:03:15|上海 | 查看全部
请问广州花都区附近是否有光学镀膜公司?
