查看: 5824|回复: 2
各位高手,谁能告诉我锗单晶的物理性质?
发表于 2007-8-3 13:21:58 | 显示全部楼层 |阅读模式
呵呵
我想要知道锗单晶材料物理性质, 最好是英文版!
发表于 2008-11-20 13:23:13 | 显示全部楼层
A brittle, silvery-gray, metallic chemical element, Ge, atomic number 32, atomic weight 72.59, melting point 937.4°C (1719°F), and boiling point 2830°C (5130°F), with properties between silicon and tin. Germanium is distributed widely in the Earth's crust in an abundance of 6.7 parts per million (ppm). Germanium is found as the sulfide or is associated with sulfide ores of other elements, particularly those of copper, zinc, lead, tin, and antimony. See also Periodic table.
Germanium has a metallic appearance but exhibits the physical and chemical properties of a metal only under special conditions since it is located in the periodic table where the transition from nonmetal to metal occurs. At room temperature there is little indication of plastic flow and consequently it behaves like a brittle material.
As it exists in compounds, germanium is either divalent or tetravalent. The divalent compounds (oxide, sulfide, and all four halides) are easily reduced or oxidized. The tetravalent compounds are more stable. Organogermanium compounds are many in number and, in this respect, germanium resembles silicon. Interest in organogermanium compounds has centered around their biological action. Germanium in its derivatives appears to have a lower mammalian toxicity than tin or lead compounds.
The properties of germanium are such that there are several important applications for this element, especially in the semiconductor industry. The first solid-state device, the transistor, was made of germanium. Single-crystal germanium is used as a substrate for vapor-phase growth of GaAs and GaAsP thin films in some light-emitting diodes. Germanium lenses and filters are used in instruments operating in the infrared region of the spectrum. Mercury-doped and copper-doped germanium are used as infrared detectors; synthetic garnets with magnetic properties may have applications for high-power microwave devices and magnetic bubble memories; and germanium additives increase usable ampere-hours in storage batteries.
发表于 2008-11-20 15:45:22 | 显示全部楼层
1. Elastic constants cij, in units of 1011 N/m2,
Formula ρ/g cm–3 T/K     C11           C12     C44                  Ref.
Ge              5.313    298    1 .2835  0.4823 0.6666       j. appl. phys., 36, 2504(1965)
2. Physico-Chemical Properties
Lattice parameters (Å, room temp.) Melting point (K) Microhardness, N/mm2 Specific heat, J/kg·K (300 K)
        Fd3m a=5.65754                                1211.35                            7644                                   321.9
Debye temp. (K) Thermal exp. Coef thermal(linear)1e–6K–1 (300K) Thermal conductivity [mW/cm·K (300K)
            374                                                      5.8                                                   640
Magnetic susceptibility(Gs/mol/cm3)
-7.684e-5
3. NONLINEAR OPTICAL CONSTANTS
NLO process Cjn × 1e20, m2/V–2      λ, μm
(–3ω,ω,ω,–ω)    C11 = 23.5 ± 12             1.06
4. Electro-optical properties
λ/μm   p11        p12      p44        p11-p12   Ref.
3.39  –0.151 –0.128  –0.072     –0.023     j. appl. phys., 49, 2589(1978)
[ 本帖最后由 handsomeland 于 2008-11-21 15:24 编辑 ]
