MEMS Optical 1x2 Switch
MEMS 1X2 SWITCH is one kind of high speed path of light Switch, this MEMS 1X2 SWITCH is micro-electronics which and the micro-mechanism technology designs based on the MEMS, thus causes the path of light through MEMS the channel to have the change to realize the path of light to transform. MEMS 1X2 SWTICH has the high stable performance and the reliability, the reliability was defers to Telcordia the GR1073 reliability inspection standards, already passed Telcordia the GR1073 examination.
Features Applications
High reliability
High Operating power (optical)
Low insertion loss
Wavelength range Broad
Switch time swiftness
non-latching Optical Reconfiguration
Instrumentation
WDM System
OADM System
OXC System
FBG Sensor System
Optical Router
Specifications
Parameter Value
Wavelength range 1290~1650nm or 1310/1490/1550±50nm
Insertion loss typ.0.4dB,max 0.6dB
Return loss ≥55dB
Polarization dependent loss <0.1dB
Cross talk Typ.60dB, Max 55dB
Repeatability ≤0.05dB
Switch time <0.2ms, max 0.5ms
Power Consumption 350 mA
Operating Voltage <5 VDC
Operating power (optical) typ 500mW, max 1500mW
Operation temperature 0~65℃
Storage temperature -40~80℃
Durability >1billion
Size (L x W x H) 26 x 9X9mm
Ordering Information
MSW Switch channel Latching or Non-Latching Fiber Type Fiber Length Connector
14=1x4
18=1x8
110=1x10
112=1x12
113=1x13
116=1x16
3232=32X32 N=Non-Latching
L= Latching S9=SMF 900um
M5=MMF 50/125/900um
M6=MMF 62.5/125/900um
XX=others 1=1.0m
2=2.0m NE=None
FA=FC/APC
FC=FC/PC
SA=SC/APC
SC=SC/PC
ST=ST/PC
LA=LC/APC
LC=LC/PC
XX=others |
