Pinnacle 3000 电源维修 Advanced Energy电源维修
998 1
发表于 2008-3-18 15:13:27|广东 | 查看全部 阅读模式
AE(Advanced Energy)维修案例 DC Magnetron Pinnacle 3000
详细介绍
Manufacturer:Advanced ENERGY
Model:AE DC Magnetron PINNACLE 3000
Input Power Specifications:
  Line Voltage:400VAC ±10%,3Phase,4Wire,50-60Hz,No neutral
  Line Current:5A per Phase,nominal line
  Line Regualtion:±1% for 10% line voltage change or a ±2% frequency change
  Overcurrent Protection:10ADC bus fuse
Output Specifiations:
  Output Power:3Kw
  Output Voltage:370-1000VDC full-power output
  Output Ripple Voltage:Component of output ripple voltage related to input line
                                      requency ±5% RMS
  Efficiency:>90% at full power
  Power factor:0.87 for loads>0.3kw;0.9 for loads>2.4kw
  Load regulation:±1% for 4∶1 load change within V-I limits of top range
  Output Actual to Readback Accuracy:Serial interface ±1%
Weight:9.1kg
Pinnacle 3000
Pinnacle 3000
powerservo 楼主Lv.7 发表于 2008-3-19 16:03:46|广东 | 查看全部
更多的电源维修资料 www.aeni.com.cn
AE电源维修 ENI/MKS电源维修...
MDX电源维修...DC直流电源 ...RF射频电源 ...
德国Spectairs授权:中国光电子和精密技术支援中心
中国光盘行业首家光盘生产设备微电子维修中心
