Agilent/HP 816189A 1525~1575nm可调光源模块
978 0
发表于 2008-3-28 09:10:17|广东 | 查看全部 阅读模式
81689A 可调光源模块出售
81689A 可调范围:1525 nm to 1575 nm
www.starbluecn.com Starblue Corporation USA shenzhen Branch
周先生 0755-26714896 13682680312 support@starbluecorp.com
我公司特价供应81689A 可调光源模块, 成色不错,质量可靠,价格适中,欢迎前来洽谈选购.
81689A Tunable Light Source Module
Description:
This module features:
Continuous sweep through full wavelength range
Mode-hop free tuning over full wavelength range
This module has the following specifications:
Wavelength Range: 1525 nm to 1575 nm
Max. Output Power: 6dBm
Wavelength Accuracy (abs.): ±0.3nm
Wavelength repeatability (typ.): ±0.05pm
Signal to Source Spontaneous Emission Ratio: ³ 39dB/nm (full wavelength range)
Operates in the C-band
Option 021 = Stranded Single Mode Fiber & Straight Contact
Since this module is tunable and has continuous output power, it can be used to test optical amplifiers, DWDM components, and complete DWDM systems.
This card is compatible with the 8166A B Multichannel System, the 8164A B Lightwave Measurement System, and the 8163A B Multimeter.
