求购
2.3k 4
发表于 2008-6-26 14:46:16|上海 | 查看全部 阅读模式
求购:如下:请有产品(最好是国产产品)的今天下午给我报价!!人民币(包括增值税)或者美金,邮箱:jack-yao@light-all.com
Photo multiplier tube & power supply        Photo multiplier tubes, side-on type, multi-alkali photocathode, window UV glass, with housing and adjustable HV Power supply for PMT        2set
        Current Amplifier for PMT output        1
Fast Photo diodes         Silicon with quartz window, area 5.1mm2, response time 0.9 µs, (unbiased)        2
        Silicon with quartz window, area 50mm2, response time  3.5 µs,  BNC connector        2
        Silicon with quartz window, Area 5.1mm2, response time 0.2 ns, (unbiased)        2
        Silicon with quartz window, Area 100mm2, response time 2 ns, BNC connector, (unbiased)        2
        InGaAS photodiode with sensing area 3mm dia         1
        InGaAS photodiode rise time 300ps, sensing area dia 120microns        2
Vernier micrometers for translation stages        25mm travel micrometer for side-driven linear stage         2
Beam Expander & laser mounts for Uniphase cylindrical He-Ne laser        Complete beam expander, Expansion power 10X, entrance aperture 2mm, focus range 1.2m to infinity, MgF coated optics and C-thread mount         1
        Rear accessory attachment, Power 20X, (to increase the magnification of the expander to 20X)         1
        Laser bezel mounting plates, 1inch dia, 4 screw model, fits with Uniphase cylindrical head (1.74”dia) laser, with 4 M3 screws         1
Corner cube prism         BK7 glass corner cube prism, 25.4mm internal dia, mounted with mounting holes surface accuracy 1/8 lamda, angle tolerance 3arc sec(http://www.amerinatech.com/Right-Angle-Prisms_cn.asp
Neutral density filter set (visible)        Filter set with six 1inch-dia ND filters
Optical densities: 03, 0.5, 1.0, 1.3, 1.5, 2.0, 2.5, 3.0 filter thickness 1.6mm        1 set
Band pass filter kit (broadband color glass)        Band pass filter kit with 8 circular band pass filters in a box, filter dia 1inch,
Color glass types: U-330, U-340, BG-12, BG-18, BG-38, VG-6, VG-9 and RT-830         1set
Laser band pass filter set        Seven-filter set in a wooden box, 24 mm dia, centers wavelengths , 457.9nm, 488nm, 514nm, 532nm, 632.8nm, 1064nm, half bandwidth<13nm        1 set
Broad band Laser Grade Mirror
        d=-25.4mm, 5mm thickness, R>99% in 400-700nm, incidence angle 0-45 deg substrate: Pyrex, laser damage threshold (pulsed, 10ns) 10J/cm2        8
Laser Grade Mirror        d=-25.4mm, 5mm thickness, R>99% in 700-900nm, incidence angle 0-45 deg  substrate: Pyrex, laser damage threshold (pulsed, 10ns) 10J/cm2        4
        d=-25mm, 5mm thickness R>99% at1064nm, incidence angle 45 deg, substrate: fused silica, laser damage threshold (pulsed, 10ns) 20J/cm2        4
Wave plates/ Polarizers        Quartz Zeroth order half wave, d=25.4mm, 532 nm, mounted on anodized cell        1
        Quartz Zeroth order half wave, d=25.4mm, 1064 nm, mounted on anodized cell        1
        Quartz Zeroth order quarter wave, d=25.4mm, 532nm, mounted on anodized cell        1
        Quartz Zeroth order quarter wave, d=25.4mm, 1064nm, mounted on anodized cell        1
        Mounted Glan Thompson polarizer, clear aperture 15mm, field angle 15, material: optical grade calcite, extinction ratio: 105 peak transmission: 90%        2
        Glass Polarizing Filter, d=42 mm, thickness 10mm, mounted        4
        Rotating polarizer holder, inner dia. 42 mm T-threaded to accept 42 mm filters        2
Right angle prisms
        UV fused silica right angle prism 25.4 mm sides, surface accuracy 1/2 lamda        2
        BK 7 glass prism, 25mm sides, surface accuracy 2 lamda        4
Holographic notch filters (optical density upto 6 at the notch wavelength)        488 nm, notch width 10nm, d=25.4 mm        1
        514 nm, notch width 12nm, d=25.4 mm,        1
        532 nm notch width 12nm, d=25.4 mm,        2
        632 nm notch width 16nm, d=25.4 mm,        1
        676 nm notch width 29nm, d=25.4 mm,        1
        785 nm notch width 39nm, d=25.4 mm,        1
        785 nm notch width 20nm, d=25.4 mm,        1
High power beam splitter        Broadband beam splitter 420-700nm, dia 50.8mm, substrate BK7 glass, flatness lamda/10, laser damage threshold (pulsed, 10ns) 5J/cm2,        6
        Broadband beam splitter 600-900nm, 50.8mm dia, substrate BK7 glass, flatness lamda/10, laser damage threshold (pulsed, 10ns) 5J/cm2,         2
        Non-polarizing 355 nm laser beam splitter, 45 deg incidence, 25mm dia, UV fused silica, 5arcsec parallelism, laser damage threshold 2J/cm2        2
Card Viewers        Infrared card viewers size: 86X54mm
IR sensitivity regions: 790-840, 870-1070nm, 1550 nm        2
Lens kit        lens kit with twenty-four 25mm dia MgF AR coated lenses in a box, PCX lenses: f=25,50, 75,100, 125,150,175,200,400mm, DCX lenses: at f =25,50,75,100,125,150,175,200, 400 mm, PCV lenses: at f=-25,-50,-100 and DCV lenses: at f=-25,-50,-100 mm        1 set
Prism holder        3inch dia circular plate prim holder with arm to hold prisms and cubic beamsplitters, with mounting hole at the base        3
Fixed Filter mounts        Fixed filter mounts to hold rectangular filters with widths between 40-70 mm, supplied with mounting post          4
        Fixed filter mounts to hold four stackable circular 1-inch filters with mounting cell accessories        3
Fixed lens mounts        Internal D=12.8mm, external dia 31.8mm, thickness 8mm, with threaded mounting ring and mounting holes        2
High performance laser diode driver        Laser diver to control both the current and temperature of a laser diode, max current 1.1 amp with current limiting, thermoelectric cooler current 3 amp. With 14-pin butterfly mount, DIL mount and 220V power supply        1
Magnetic Mounting Base        Magnetic mounting base with component mounting plate (metric holes), with ON/OFF switch, external dimensions: 66X83X51mm (approx)        10
Lab jack        Precision laboratory jack with metric holes, platform dimensions 160X100X12mm (approx), movement range 80-123mm, weight capacity 10kg (approx)        2
Rack-and-pinion stages        X-Y-Z axis metric stage with mounting holes, rack-and-pinion movement 60 mm travel with right-angle adapter plates         6
        X-Y axis metric stage with mounting holes, rack-and-pinion movement 60 mm travel         6
Iris diaphragms        Adjustable mounted iris diaphragms
min aperture 0.8mm, max  25 mm (approx).        6
Optics cleaning Material         Optics Cleaning Tissue, Cleaning Chemicals, etc., dust blower (2), tweezers (2)        1 set
Non-linear Crystals        Laser grade BBO (Beta-Barium Borate)
Type I (size 4X4X12-15mm, cut angle 21deg)
Type II (size 7X4X15-20mm, cut angle 37deg)
Laser-grade LBO (Lithium Triborate)
(size 5mmX5mmX20mm) approx. Types I and II
Quartz Cells        Rectangular cells:
Dimensions (external) 12.5X12.5X48mm (approx), dimensions (internal) 10X10mm with 4 polished sides
Cylindrical cells:
10mm diaX 35-50mm height (approx)
GROUP F:         Optical Table & Breadboard
Items        Specification        Qty
Optical Table including air-mounted legs        Stainless steel honeycomb tabletop (with metric holes) with 4mm thick ferromagnetic stainless steel surface, 1.5X3.6m, 8 inch thick with M6 holes on 25mm grid        1
        Air mount isolator, 4 Legs, 28 inch height
With foot-pump pressurization, max load per 4 isolator 3600kg, vertical and horizontal resonant frequencies<2Hz
        4 legs
Optical breadboard        Optical bread board (metric) with ferromagnetic stainless steel surface, 4ftX6ft, thickness 2inch (approx), with internal damping, with M6 holes on 25mm grid        1ll.com
[ 本帖最后由 jack88 于 2008-6-26 15:17 编辑 ]
回复|共 4 个
sino-laser Lv.8 发表于 2008-6-26 16:11:30|北京 | 查看全部
我靠, 这是准备什么实验项目啊?
看这些东西, 光准备下来就得半年.....
harber Lv.2 发表于 2008-6-27 11:29:00|四川 | 查看全部
成都炬科光学希望与你合作!
hoogoogol Lv.12 发表于 2008-6-27 11:37:10|北京 | 查看全部
很难搞齐
想往国外倒?
真想做联系大恒光电吧
呵呵
hoogoogol Lv.12 发表于 2008-6-27 11:39:30|北京 | 查看全部
light-all
光傲
这个名字有特点....
