ASM公司招聘赴新加坡工作R&D工程師
2.7k 2
发表于 2008-7-9 09:57:27|广东 | 查看全部 阅读模式
ASM Pacific Technology Ltd is the world’s largest assembly and packaging equipment supplier for the semiconductor industry.  Listed in Hong Kong since 1989 (ASMPT), ASM Pacific Technology Ltd is 54% owned by ASM International N.V., a NASDAQ listed supplier of wafer processing equipment.  ASM Pacific Technology Ltd. with headquarters in Hong Kong has operations in Shenzhen, China, Singapore and Malaysia.  We are a leading supplier of a full line of assembly and packaging equipment and process solutions for the semiconductor, photonics and optoelectronics industries. Our financial strength and R&D resources allow us to provide customers with total solutions, process innovation, package development and factory automation.  Further details can be found at http://www.asmpacific.com/
For details of company profile and its products, please visit our website: www.asmpacific.com
Interested applicants may send their resumes to humanresource@asmpt.com, with indication of position interested.  We regret that only shortlisted candidates will be notified.
Location of all positions is in Singapore.
CAE Engineers (Working in Singapore)
You will be involved in static and dynamic strength/stiffness analysis of semiconductor packaging equipments using computer-aided engineering software.
Requirements:
Masters/PhD Degree in Mechanical engineering
Good understanding in stress/vibration analysis with finite element technique
Machine design skills and experimental skills are a plus
Control Engineer (Working in Singapore)
You will be responsible for the design, development and sustaining of high performance motion control system. This will require you to be strong in control theory and its application as well as familiar with other disciplines of Mechatronics.
Requirements:
• Masters or PhD Degree in Electrical/Mechanical/ Mechatronics Engineering, specializing in Control
• Proficient in MATLAB ‘C’, real time system, sensor, change motor driver systems
• Analytical, hands-on problem solver and creative
Computer Vision Engineer
You will be responsible for conducting research in computer vision technology; as well as developing advanced vision algorithms and applications for machine automation and visual inspection.
Requirements:
• PHD, Masters or Degree in Electronics Engineering/ Computer Science or a relevant discipline with strong technical background in the field of computer vision and image analysis
• At least 2 years’ relevant experience
• Knowledge of image processing C or C++
Electronic Engineers (Working in Singapore)
You will be responsible for developing software for automation and control applications, including advance algorithm to control machines. You will also test and debug the software and provide technical support at customers’ sites.
Requirements:
• BA/BS/MSC Degree in Electronics/Electrical/Computer Science/Physics
• Good working knowledge of C/C++ and OOP
• Experience in control/automation software, system programming and software testing is a plus
Firmware Engineers (Working in Singapore)
You will design, develop, deploy and sustain firmware for hard real-time embedded control applications. You are expected to provide technical expertise and solutions to production and field for the deployment of controllers.
Requirements:
• Masters/Degree in Computer/Electrical & Electronics/Control Engineering
• Knowledge of the application of real-time operating system, software methodology,
  microprocessor architecture, control strategy and programming languages such as C/C++ and
  Assembly
Mechanical Engineer <Post A> (Working in Singapore)
You will be involved in conceptional mechanical design in the area of semiconductor equipment, including providing pneumatic circuit and optical design support.
Requirements:
&#8226;        Masters Degree in Mechanical Engineering, fresh graduate is welcome
&#8226;        Familiar with ProE or Solid Edge/Work and MS Office
&#8226;        Good understanding of material and fundamental mechanism with basic knowledge of fabrication process
&#8226;        Basic CAE experience is a plus
&#8226;        Passion for mechanical design and R&D
&#8226;        Able to identify problems and meet targets
Mechanical Engineers <POST B> (Working in Singapore)
You will perform automatic semiconductor assembly equipment design as well as material handling and tooling design. You will also be involved in continuous improvement activities and field trips with a focus in mechanical design.
Requirements:
&#8226; Degree in Mechanical/Production Engineering
&#8226; Proficiency in SolidEdge, Pro-E and Autocad is a must
&#8226; Willing to travel
Mechanical Engineers <POST C> (Working in Singapore)
You will be responsible for mechanical design and development of automated mechanism and high speed/acceleration precision mechanism. You will conduct vibration studies, CAE analysis and improvement on mechanical structures or high speed/acceleration motion mechanisms.
Requirements:
&#8226; Degree or Higher in Mechanical Engineering
&#8226; Proficient in SolidEdge, Autocad and CAE
Material Engineer (Working in Singapore)
You will perform failure analysis and material studies on semiconductor assembly process and equipment.
Requirements:
&#8226;        Good Degree in Material Science
&#8226;        Familiar with the operation of analytical equipment (eg. FESEM, CSAM)
Senior / Process Engineers (Working in Singapore)
You will provide process support for the Encapsulation Solutions Group; as well as providing solutions for advance encapsulation of semiconductor, mold design improvement; encapsulation technology development and new material evaluation.
Requirements:
&#8226; Good Graduate Degree (Master and PhD) in Chemistry (all fields), Physics, Materials Science or Engineering, Chemical Engineering, Engineering (Areas of Fluid Mechanics, Heat Transfer or Semiconductor)
Senior/ Optical Engineers (Working in Singapore)
You will be responsible for research and development in optical and lighting system for machine automation using area cameras and line scan cameras and optical instrumentation for high precision metrology.
Requirements:
&#8226;        Degree or high degree holder in optical engineering or related field
&#8226;        Experience in precision optical design or laser optical design
&#8226;        Familiar with using Zmax in system design and optical flow simulation
&#8226;        Responsible to design optic for advanced 3D inspection machine
回复|共 2 个
扬帆起航 Lv.14 发表于 2008-7-9 10:03:48|上海 | 查看全部
代sir,还在招聘啊???光学工程师招了有好几年了,招了几个呀?最好还是先吧工资范围给出来吧,免得应聘人员白跑一趟。
miao2 Lv.2 发表于 2008-7-10 10:07:17|新加坡 | 查看全部
原帖由 daimingbo 于 2008-7-9 09:57 发表
ASM Pacific Technology Ltd is the world’s largest assembly and packaging equipment supplier for the semiconductor industry.  Listed in Hong Kong since 1989 (ASMPT), ASM Pacific Technology Ltd is 54%  ...
帮lz顶一下。
先到先得,送完为止。呵呵。
