二手AQ8423Z/光放大器分析仪
800 0
发表于 2008-7-22 13:24:41|广东 | 查看全部 阅读模式
[原创]二手AQ8423Z/光放大器分析仪
详细资料:
Optical Amplifier Analyzer
AQ8423Z
Dual Band Optical Amplifier Analyzer
Switchable C-band and L-band
The AQ8423Z is a unique dual-range optical amplifier
analyzer. In conjunction with an external optical
spectrum analyzer (OSA) and light sources (such as
tunable laser sources or DFBs), the AQ8423Z can
measure gain and noise figure (NF) of optical amplifiers
both in C-band and L-band. Two testing wavelength
ranges can be switched internally by simple
operation.
The AQ8423Z employs the proven "Pulse
method" technique. It utilizes 1 MHz modulation frequency,
which is high enough to suppress a rise of
ASE (amplified spontaneous emission) level during
off signal. The AQ8423Z can achieve very high
accuracy in ASE measurement resulting in accurate
NF measurement.
Since the AQ8423Z can eliminate all DWDM signals
simultaneously during ASE measurement, it
can obtain measurement results under actual
DWDM operational conditions.
Features
 Pulse method with 1 MHz modulation
High enough frequency to suppress a rise of ASE
during a measurement
 C- and L-band measurement capability
Measurement range is switchable, either to
C-band (1520-1580 nm) or L-band (1560-1620 nm)
 DWDM measurement mode
A DWDM amplifier, with multi-tone signals, can be
measured under its actual operational conditions.
 Hands-free calibration
New hands-free calibration function, added to full
user calibration feature, makes daily calibration simple
and quick.
 Maximum test channel: 200 channels
 Minimum channel spacing: 25 GHz
In conjunction with AQ6317 ANDO optical spectrum
analyzer
AOM1 OC OSW AOM2
ATTN OSW ISO
OPM
EXT IN REF IN
MON
OUT IN OSA
AQ4321D Tunable Laser Source
(1520-1620 nm)
AQ6317B Optical Spectrum Analyzer
(600-1750 nm)
ATTN: Optical Attenuator AOM1,2: Acousto Optic Modulator ISO: Isolator
OC: Optical Coupler OSW: Optical Switch OPM: Reference Optical Power Meter
Signal and ASE detection timing
Example of measurement system configuration
Test data example
Test results displayed on AQ8423Z DFB-LD characteristic on AQ6317B’s display
Notes
. Optical spectrum analyzer has to be ANDO product (AQ6317B is recommended).
. Optical spectrum analyzer is fully controlled by AQ8423Z via GP-IB during a measurement.
. A bunch of DFB-LDs and tunable laser source can be used as an external light source. Tunable laser source from different
manufacturers can be controlled via GP-IB by AQ8423Z.
* Left picture shows a system configuration example by AQ8423Z, AQ6317B and 18-channel DFB-LD.
1. Signal Power
AOM1
AOM2
2. ASE Power
AOM1
AOM2
Effect of AOMs on optical
spectrum
EDFA Output AQ8423Z Output for ASE Meas.
WDM Signals + ASE ASE
The AQ8423Z modulates signals from external
light sources with AOM1, and AOM2 selects
the timing to measure, signal or ASE (Amplified
spontaneous emission).
When AOM2 is set for ASE measurement,
AOM2 eliminates the source signal and SSE
(Source spontaneous emission) without affecting
the ASE level (to increase input power, a
booster amplifier can be added to external
light sources, the SSE includes ASE of the
booster amplifier in this case). Thus, the
AQ8423Z can measure the ASE at a signal
wavelength very accurately.
The modulation frequency is also very
important. It strongly affects ASE measurement
accuracy, which results in an error on NF.
In order to minimize ASE measurement errors,
the AQ8423Z modulates a source signal with
1 MHz, which is high enough to suppress a
rise of ASE level, to obtain high accuracy.
Specifications
Wavelength range 1) C-Band mode (1520 to 1580 nm)
L-Band mode (1560 to 1620 nm)
DUT input power range 2) -45 dBm to +10 dBm
DUT output power range +24 dBm or less
Accuracy 3) Gain ±0.2 dB
NF ±0.3 dB
DUT input power ±0.2 dB
DUT output power ±0.2 dB
Reproducibility 3) Gain ±0.1 dB
NF ±0.2 dB
DUT input power ±0.1 dB
DUT output power ±0.1 dB
Applicable fiber Single mode 10/125 μm
Applicable optical connector FC (SPC)
Minimum channel spacing 4) 25 GHz
Maximum channel 4) 200 channels
Measurement time Approx. 5 minutes (40 channels)
Warm-up time Approx. 1 hour after power on
Measurement function Wavelength dependence, input power dependence, stability
Display function Wavelength-Gain, wavelength-NF, input-output, input-Gain, input-NF, time-gain, time-NF, time-input,
time-output, measurement data list, 1-, 2- and 4-waveform display
Calibration function Input power, output power, OSA effective resolution, DUT delay time
Data storage FDD (3.5-inch 2HD, 1.2/1.44MB), internal memory (for 32 waveforms)
Printer Built-in high-speed printer
Interfaces GP-IB (2-ports), video output (VGA compatible)
Display 9.4-inch color LCD
Power requirements AC100 to 120 V, AC200 to 240 V, 48 to 63 Hz, approx. 200 VA
Environmental conditions Operating temperature: 15 to 35°C
Storage temperature: -10 to 50°C
Humidity: 80% or less (no condensation)
Dimensions and mass Approx. 425(W) x 222(H) x 450(D) mm, approx. 20 kg
Notes
1) Either C-Band mode or L-Band mode
2) Maximum input power is related to the output power of light source.
3) ±1°C, between 15 and 35°C
4) In conbination with AQ6317B optical spectrum analyzer
深圳市嘉惠捷科技有限公司
黄先生
手机:13928415151
TEL:0755-89437676
MSN:seanhuang82@hotmail.com
Mail:test-e@test-e.com
QQ:627906231
Http://www.test-e.com
