The complete solution for liquid lens testing to ensure quality and optimize production lines.
Measure
optical power and hysteresis of the power curve independently depending on applied voltage
Assess
the optical quality, prism and centering errors individually compared to optical power
Determine
temporal transient response dynamic including optical power and aberration evolution while applying voltage
Gage
applied voltage at the lens’ outer edge, overall consumed current and the ratio of applied versus consumed voltage
Welcome to the future of liquid lens testing. The SL-Sys is a turnkey solution that provides industrial liquid lens manufacturers with an unparalleled quality control platform. It enables you to go beyond current testing methods that rely solely on focal length and MTF measurements by ensuring the overall lens quality as a function of true optical quality, directly on the production line.
Inside the system’s sleek outer casing is a technology treasure chest that includes a fully-calibrated, solid-state1 optical bench that ensures perfect optical conjugation between the lens and the testing plane.
Quality control is fast, simple and reliable via an ergonomic PC software interface. Each unit contains perfectly collimated light source functioning at 630nm, an AC generator that provides ±10V of power with 16 bit resolution, a 20x charge amplifier, and a system that synchronizes the wavefront sensor with the generator. As an added security feature, electric current to the lens is cut as soon as the access panel is opened.
The SL-Sys goes beyond simply indicating if a lens is optically sound or not. The system’s advanced features enable you to limit waste by detecting problems earlier in the manufacturing process than other products, as well as by helping to understand their origin and to correct for irregularities using the provided data. Even more, the SL-Sys lets you compare the lens’ measured attributes versus its best theoretical optical performance, allowing you to set your own proper quality/cost standards.
王 咏
北京路源科技有限公司
地址: 北京市海淀区车公庄西路甲19号华通大厦A座539室
邮编: 100048
电话: 010-68482707/09/10 ext.118
传真: 010-68485151
E-mail: wangyong@luy-tech.com
[ 本帖最后由 wy_laser 于 2008-8-6 13:52 编辑 ] |
