求助:怎样理解光纤的模式?
let me try!
For multi mode fiber, there are many different direction ray that can go throught the whole fiber in acceptant core (NA), those ray are called mode of fiber.as you know , the ray’’s track has itself period, that is what you have mentioned above.
for single mode fiber: because the core is very small such as 3uM, it is very near the incident light wavelength. so we have to use the theroy of waveguide to solve this problem, maybe it is very complex but we just need know the result that the SM fiber just can contain only 1 mode so-called base mode in current wavelength. |
