光开关是一种光路转换器件。在光纤传输系统,光开关用于多重监视器,LAN,多光源,探测器和保护以太网的转换。在光纤测试系统,用于光纤,光纤设备测试和网络测试,光纤传感多点监测系统。 科毅公司推出的机械光开关,MEMS光开关,1XN系列光开关(机械式光开关,1xN 光开关,多模光开关,单模光开关,高功率光开关,高速光开关,光开关厂家,非锁定光开关,1x2光开关,2x2光开关,8x8光开关,4x4光开关,光开关销售商)是基于自由空间设计的机械式光开关,广泛应用于光交叉连接,光纤线路保护,光信息分插复用与解复用, 以及测试系统波长切换,光传感系统,激光医疗设备的通道切换等等。该产品结构紧凑,体积小,具有工作波长范围宽,响应速度快,插损低,偏振相关损耗低等特点。我们能够满足各种不同的设计需要,也可以提供其他器件的整合来完成不同功能的模块和微系统。Core ray’s 1*N optical switches are mechanical optical switch which base on the free space design. The switches are use in light crossing connect, fiber protections, linght massage drop reuse and resolve, change the wave length of testing system, light sensing system, medical equipment channel change and so on. It’s small, can work in the wide area of the wave length, also it react fast, low insertion lose, polarized low lose est. We can satisfy all your need in design, meanwhile prove other equipment to complete the modify and mini system which has different faction. 特征:应用:工作波长范围宽网络监控和切换低损耗光纤线路保护响应速度快光传感系统体积小,可灵活设计激光医疗设备光切换高稳定性和高可靠性测试系统,测量装置参数:指标波长范围 (nm) wavelength area(nm) 500~1650插入损耗 (dB) insertion lose( dB)1.0切换时间 (m/s)swithing time8波长相关损耗 (dB)0.3 通道串扰 (dB)-55偏振相关损耗 (dB)0.1重复性 (dB)±0.05回波损耗 (dB)-55开关类型 锁定/ 非锁定承载功率 (mW)≤ 500使用寿命10 Millions 工作温度 (℃)-5 ~ +70储藏温度 (℃)-40 ~ +85工作电压 (V)4.5~5.5工作电流 (mA)≤ 120封装尺寸 (mm)56(L) x 80 (W) x 15 (H)订购信息:类型一类型二类型三波长出纤类型出纤长度连接器XXXXXXXXX OSWS=单模M=多模L=锁定N=非锁定11=1×112=1×222=2×2 (Full)AD=2×2(Add/Drop)14=1×418=1×81A=1×1613=1310±40nm15=1550±40nm85=850±40nm35=1310&1550nm38=1310&850nm58=1550&850nm1=125um bare fiber2=900um loose tube1=1m2=2m1=None2=FC/APC3=FC/PC4=SC/APC5=SC/PC6=ST7=LC
供应数量: 100000 包装说明: 纸盒包装 产品规格: 56(L) x 80 (W) x 15 (H)
电话:15878753427,刘小姐
光缆在线监测系统(4U光开关).pdf
(1.75 MB, 下载次数: 0)
1x24MEMS OSW1550& 1625nm.pdf
(308.93 KB, 下载次数: 2)
MXN型光开关.pdf
(1.43 MB, 下载次数: 0)
1XN机械式光开关.pdf
(3 MB, 下载次数: 6)
