高倍聚光光伏可拆卸型二次反射镜设计与研究
Design and research of removable secondary mirror in high concentrated photovoltaic technology
下载全文
高倍聚光光伏可拆卸型二次反射镜设计与研究.pdf
(958.19 KB, 下载次数: 0)
作 者:郭丽敏 卫明 杨光辉 代明崇 王智勇
Guo Limin,Wei Ming,Yang Guanghui,Dai Mingchong,Wang Zhiyong(Institute of Laser Engineering, Beijing University of Technology, Beijing 100124, China)
机构地区:北京工业大学激光工程研究院,北京100124
出 处:《红外与激光工程》 EI CSCD 2014年第43卷第10期 3338-3341页,共4页
Infrared and Laser Engineering
摘 要:高倍聚光光伏技术是将垂直入射于菲涅耳透镜上的太阳光聚焦到电池片上,通过光电转换产生电能,但实际应用时,由于跟踪器跟踪精度低、支架受风会抖动等因素存在,无法保证太阳光始终垂直入射于菲涅耳透镜。针对该问题,在菲涅耳透镜和太阳能电池之间增加一个可拆卸的倒置的去掉顶部的棱锥形二次反射镜来提高聚光光伏的接收角,给出了具体的设计实例,并应用Solidworks软件和Tracepro软件对设计实例进行了计算机光学模拟。结果证实该二次反射镜能很好地提高聚光光伏的接收角,并改善菲涅耳透镜聚焦光斑的能量均匀性。
The direct fraction of sun irradiation is used to focus on Fresnel lens in High Concentrated Photovoltaic technology, electric energy is produced through photoelectric inversion. However, because of many factors in practice like the low tracking accuracy of tracker, structure vibration by winds and atmospheric scattering, the direct normal irradiation to the Fresnel lens can not be guaranteed. To solve this problem, a removable secondary mirror whose shape was a reverse cone with no top was added between the Fresnel lens and solar cells to increase the acceptance angle of the solar module. A design example was given, and analyzed by optical simulation with the software of Solidworks and Tracepro. The conclusion indicates the removable secondary mirror can increase the acceptance angle and improve the irradiance uniformity of the focus spot.
关键词:菲涅耳透镜 高倍聚光光伏 二次反射镜 光学设计
Fresnel lens high concentrated photovoltaic secondary mirror optical design ; |
