高光能利用率极紫外光刻波纹板照明系统设计
Optical Design of High-Efficiency Ripple Plate Illuminator for EUV Lithography
下载全文
作 者:梁欣丽 李艳秋 梅秋丽
Liang Xinli Li Yanqiu Mei Qiuli( Key Laboratory of Photoelectronic Imaging Technology and System, Ministry of Education, School of Optoelectronics Beijing Institute of Technology, Beijing 100081, China)
机构地区:北京理工大学光电学院光电成像技术与系统教育部重点实验室,北京100081
出 处:《光学学报》 EI CSCD 2015年第3期 294-300页,共7页
Acta Optica Sinica
基 金:国家科技重大专项(2012ZX02702001-002)
摘 要:针对极紫外光刻照明系统光能利用率低的问题,设计了一套高光能利用率极紫外光刻波纹板照明系统。该系统中波纹板面形采用柱面镜阵列,降低了加工难度;并且根据波纹板反射光线的特性,确定了由修正型复合抛物面聚光镜与二次曲面反射镜组作为中继镜组的结构。整个系统仅采用四片反射镜且其中两片反射镜为掠入射,与传统的极紫外光刻照明系统相比,有效地提高了系统的光能利用率。对一套数值孔径0.33的极紫外光刻投影物镜,给出了与之相匹配的波纹板照明系统设计实例。仿真结果表明,系统的光能利用率可达39.7%,掩模上弧形照明区域扫描方向的积分不均匀度小于2.7%,验证了该设计的可行性和有效性。
A high- efficiency ripple plate illumination system for extreme ultraviolet(EUV) lithography is proposed. A cylindrical mirrors array is used as ripple plate mirror to simplify the system. By analyzing the characteristics of reflection on ripple plate, we design a relay system with a modified compound parabolic concentrator and two conic mirrors to reduce the efficiency loss caused by excessive number of reflective mirrors. Compared with the traditional EUV lithography illumination system, it greatly improves the system′s efficiency. A design example for a numerical aperture(NA) 0.33 projection objective is given and the efficiency of the illuminator is 39.7% while the slit non- uniformity of the scanning energy distribution is 2.7% in a prescribed arc area, which proves the feasibility of the design.
关键词:光学设计 波纹板照明系统 反射系统 极紫外光刻
optical design ; ripple plate illumination system ; catoptric system ; extreme ultraviolet lithography ; |
