新型激光投影显示照明系统设计
The Illumination System Design for New Laser Projection Display
下载全文
新型激光投影显示照明系统设计 (1).pdf
(973.2 KB, 下载次数: 3)
作 者:牛磊[1,2,3] 李湘宁[1,2,3] 隋峰[1,2,3]
NIU Lei,LI Xiangning,SUI Feng(1. School of Optical-ElectricaI and Computer Engineer, University of Shanghai for Science and Technology, Shanghai 200093, China; 2. Shanghai Key Lab of Modern Optical System, Shanghai 200093, China; 3. Research Center of Optical Instruments and System Engineering, Ministry of Education, Shanghai 200093, China )
机构地区:[1]上海理工大学光电信息与计算机工程学院,上海200093 [2]上海市现代光学系统重点实验室,上海200093 [3]教育部光学仪器与系统工程研究中心,上海200093
出 处:《光电工程》 CSCD 2015年第42卷第3期 77-82页,共6页
Opto-Electronic Engineering
基 金:国家863高技术计划项目(2009AA32708)
摘 要:激光投影显示技术是显示技术近年来的发展趋势,本文设计了一种新的针对激光光源的照明系统,它由激光器阵列作为光源、改进的卡塞格林汇聚系统、光纤导光棒、激光散射器及4f中继系统组成。改进的卡塞格林汇聚系统收集激光器阵列发出的光能耦合进光纤,激光在光纤中传输,使光束混合均匀,激光散射器对光束匀光及整形,通过4f中继系统照射在0.61英寸(1英寸=2.54 cm)LCOS芯片上,形成高效均匀的照明光束,光纤可弯曲可合束能实现超高亮度照明。用光学扩展量评价了系统的光能利用率。最后通过软件模拟,验证了方案的可行性。
In recent years, the laser display is the tendency of the display technology. A new kind of illumination system is proposed for laser light source, which consists of laser array light source, improved Cassegrain optical system, fiber, laser diffuser and 4f-relay system. In order to obtain efficient and uniform illumination distribution, the light from the laser is collected by the improved Cassegrain optical system and then coupled into the fiber where it’s been mixed and uniformed. Then the beam is collected on the 0.61-inch LCOS chip through the 4f-relay system after being shaped by the laser diffuser. The system could achieve high brightness illumination because the fiber can be bent and combined, and the optical extension is evaluated based on optical extend. Finally, the designed system is ray tracing simulated in optical software to verify the feasibility of the method.
关键词:照明系统 光学扩展量 光纤导管棒 激光散射器 激光投影显示
illumination system ; optical extend ; fiber ; laser diffuser ; laser display ; |
