SPECIFICATIONS
Model number HN-35G-IR-A HN-50G-IR-A
Part number 1504 1506
Operating wavelength 3.39µm 3.39µm
Mode spacing (MHz) 165 88
Band width (MHz) 280 280
Number of longitudinal modes 2 3
Coherence length (m) 1.07 1.07
Cavity length (m) 0.9 1.7
Bore diameter (mm) 5.5 5.5
Beam waist radius @ 1/e2 points (mm) 0.596 0.880
Beam diameter (mm) 3.39 4.52
Beam divergence, full angle (mr) 3.62 2.45
Discharge current (mA) 44 96
Output power, minimum (mW)
Note: TEM00 not guaranteed 9.0 20
Output power, nominal (mW)
Note: TEM00 not guaranteed 11.0 25
Amplitude stability 5% RMS after 45 minutes warmup
Long term amplitude stability 5%/hour/° C after one hour
Beam amplitude noise (0.2 to 150kHz) 2% RMS
Angular beam drift (mr) 0.1 with stable room temperature (20.5 ± 1° C) after 1 hour
Operating temperature 10 to 43 ° C
FDA/CDRH laser class IIIb
CDRH compliance CRF 1040.1
Laser head dimensions (inch/mm) 6.81 x 5.38 x 41.88 (172.9 x 136.6 x 1063) (HN-35G-IR-A)
7.48 x 17.25 x 16 (172.9 x 136.6 x 1873.3) (HN-50G-IR-A)
Power supply dimensions (inch/mm) 7.48 x 17.25 x 16 (190 x 438.2 x 406)
(height - width depth)
Laser head weight (lb/kg) 38.7 (17.6) HN-35G-IR-A
52 (23.6) HN-50G-IR-A
Power supply weight (lb/kg) 39 (17.7)
System shipping weight (lb/kg) 120 (54.5) HN-35G-IR-A
285 (129.5) HN-50G-IR-A
Dimensional shipping weight (lb/kg) 157 (71.4) HN-35G-IR-A
387 (175.9) HN-50G-IR-A
Warranty 12 months on parts and labor, FOB factory
National Standards compliance meets ANSI Z136.1-1993
Military Standards compliance meets MIL-T-22800E, para. 3.9
Optional tabletop mounting kit model ALM-35/50, part number 51341
