清理电脑发现里面的老文章免费分享,30个无限制下载。 ...
3.3k
屋檐上的狗
2010-6-2 01:49:45
2006年激光器市场分析.pdf
(344.59 KB, 下载次数: 7)
2010-6-2 01:43 上传
点击文件名下载附件
2007年二极管激光器市场增势减缓.pdf
(486.51 KB, 下载次数: 5)
2010-6-2 01:43 上传
点击文件名下载附件
Application Note Volume Bragg Grating Alignment.pdf
(428 KB, 下载次数: 6)
2010-6-2 01:43 上传
点击文件名下载附件
Coupled-wave analysis of apodized volume gratings.pdf
(172.53 KB, 下载次数: 4)
2010-6-2 01:44 上传
点击文件名下载附件
Frequency-narrowed external-cavity diode-laser-array bar.pdf
(116.21 KB, 下载次数: 2)
2010-6-2 01:44 上传
点击文件名下载附件
High brightness laser design based on volume Bragg gratings.pdf
(1.18 MB, 下载次数: 2)
2010-6-2 01:44 上传
点击文件名下载附件
High power with high efficiency in a narrow single-lobed beam from a diode laser.pdf
(430.96 KB, 下载次数: 2)
2010-6-2 01:44 上传
点击文件名下载附件
High-brightness narrow-line diode source with volume Bragg-grating feedback.pdf
(304.09 KB, 下载次数: 2)
2010-6-2 01:44 上传
点击文件名下载附件
High-frequency Bragg gratings in a photothermorefractive glass.pdf
(100.69 KB, 下载次数: 2)
2010-6-2 01:45 上传
点击文件名下载附件
Laser Marking Mechanism and Quality Characteristics.pdf
(152.62 KB, 下载次数: 2)
2010-6-2 01:45 上传
点击文件名下载附件
lm_stabilizer.pdf
(290.12 KB, 下载次数: 2)
2010-6-2 01:45 上传
点击文件名下载附件
Modeling of Gaussian beam diffrraction on volume Bragg gratings in PTR glass.pdf
(354.88 KB, 下载次数: 3)
2010-6-2 01:45 上传
点击文件名下载附件
Modeling of phase volume diffractive gratings part 1 transmitting sinusoidal uni.pdf
(626.76 KB, 下载次数: 2)
2010-6-2 01:45 上传
点击文件名下载附件
Narrow beam divergence of laser diodes with a Bragg grating in external cavity.pdf
(70.53 KB, 下载次数: 3)
2010-6-2 01:45 上传
点击文件名下载附件
Optimizing and Stabilizing Diode Laser Spectral Parameters.pdf
(802.4 KB, 下载次数: 3)
2010-6-2 01:46 上传
点击文件名下载附件
Performance enhancement of the high-power laser diodes and arrays by use of the .pdf
(100.38 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Power efficiency of a semiconductor laser with an external cavity.pdf
(123.02 KB, 下载次数: 3)
2010-6-2 01:46 上传
点击文件名下载附件
Spectral stabilization of laser diodes by external Bragg resonator.pdf
(163.4 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Thin and thick diffraction gratings_Thin matrix decomposition method.pdf
(197.18 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Unexpected properties of a laser resonator with volumetric Bragg grating end mirrors.pdf
(93.77 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Volume Bragg semiconductor lasers with near diffraction limited divergence.pdf
(546.98 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Volumetric Bragg Grating Dramativally Cuts Laser Bandwidth.pdf
(268.74 KB, 下载次数: 2)
2010-6-2 01:46 上传
点击文件名下载附件
Wavelength-tunable narrowband high-power diode laser stacks based on volume Brag.pdf
(412.67 KB, 下载次数: 3)
2010-6-2 01:47 上传
点击文件名下载附件
国际激光器市场动向.pdf
(98.67 KB, 下载次数: 8)
2010-6-2 01:47 上传
点击文件名下载附件
激光加工技术的发展.pdf
(247.55 KB, 下载次数: 5)
2010-6-2 01:47 上传
点击文件名下载附件
激光器市场回顾与展望二极管激光器.pdf
(488.96 KB, 下载次数: 7)
2010-6-2 01:47 上传
点击文件名下载附件
激光市场综述.pdf
(107.59 KB, 下载次数: 6)
2010-6-2 01:47 上传
点击文件名下载附件
瓦级半导体激光器光束整形装置.pdf
(87.02 KB, 下载次数: 12)
2010-6-2 01:47 上传
点击文件名下载附件
现代光学工程(en).pdf
(275.76 KB, 下载次数: 5)
2010-6-2 01:47 上传
点击文件名下载附件
现代光学工程1(en).pdf
(188.48 KB, 下载次数: 8)
2010-6-2 01:47 上传
点击文件名下载附件
共 2 个
sunnymyselfmax
Lv.3
2010-9-14 13:28:01
安徽
不免费啊
zhouytang
Lv.5
2010-11-25 17:55:27
好东西
屋檐上的狗
工程专家
如何在安卓手机上激活正版PowerAMP音乐播放器
2016-08-10
浅谈我国太阳能利用玻璃的消费现状及趋势
2015-07-13
太阳能电池光谱响应度测量方法的分析与比较
2015-07-13
太阳能光电–热一体化与热泵耦合系统的热力性能实验研究
2015-07-13
基于太阳能光伏并网发电系统的设计探讨
2015-07-13
303 人气
26571 阅读
30079 阅读
30187 阅读
27179 阅读
35486 阅读
光电材料纳米材料新材料
