13.89 million total pixel image sensor
Full 35 mm frame CMOS sensor (24 mm x 36 mm)
Selectable image size—
4500 x 3000 (13.5 million recorded pixels)
3000 x 2000 (6.1 million recorded pixels)
2250 x 1500 (3.4 million recorded pixels)
1125 x 750 (0.8 million pixels)
Selectable ISO from 80 to 800 in 1/3-stop increments Resolution ISO Range
100% (~13.5 million recorded pixels) 80 - 400
67% (~6.1 million recorded pixels) 80 - 800
50% (~3.4 million recorded pixels) 80 - 800
听说价格只有55000网上价格低4000usd,不知是不是在中国的真实价格。
网上只有高坚一家再买。又听说发布的样张太差,结果比加能1ds还不如,但是真的吗,另外这东东的信噪比如何?请高手参谋。
Burst rate—1.7 frames/second
Burst depth—7 images (full-resolution DCR mode)
LCD user interface
Magnesium-alloy enhanced camera body and SLR functionality
NIKON F-mount
DTTL-enabled hotshoe and pop-up flash
PC connector for external flash sync
10-pin remote trigger port
Vertical shutter release
Orientation sensor (detects camera orientation +/- 90 degrees from horizontal, rotated about optical axis)
Custom Li-Ion battery
~400 shots per battery charge
12-bit dynamic range
Composite-video out桸TSC or PAL
Single channel audio
