物方远心光路设置?
4.3k 5
发表于 2003-11-10 17:58:00|浙江 | 查看全部 阅读模式
在ZEMAX和CODE V里都有物方远心光路的设置,OSLO里有没有啊?
好象没看到!
回复|共 5 个
huanglin 楼主Lv.12 发表于 2003-11-11 17:24:00|浙江 | 查看全部
物方远心光路设置?
陈教授给我的答复,不是很明白,大家帮我理解一下,谢谢!
I quessed that you are talking about telecentric.
This is actually very simple to do by using solve, e.g., by controlling chief ray. Similarly, afocal can be achieved easily by the default solve, say by controlling axial ray. (Of course, you don’’t have to limit yourself to condiser these rays only in image space.) You can also make these (telecentric or afocal) by rearranging the setting in setup without too many efforts. Of course, you can settle these (telecentric or afocal, for examples) by using optimization (operands). Which is better? Hard to say. It depends greatly on the nature of the design task you are working on.
There are many different kinds of solve in OSLO as default function, including some very unique ones, e.g., the Wassermann-Wolf solve.
In future version of OSLO, the user will be allowed to implement their own solve as to my knowledge. That will greatly enhance the design capability.
DOE Lv.10 发表于 2003-11-12 07:05:00|美国 | 查看全部
物方远心光路设置?
在surface data spreadsheet中点击Gen按钮,再在Ray aiming mode中选取Telecen. pupil mode即可。
huanglin 楼主Lv.12 发表于 2003-11-12 15:45:00|浙江 | 查看全部
物方远心光路设置?
多谢!原来这一项只有物距有限远时才显示的。难怪找不到。
meng Lv.6 发表于 2004-4-29 23:44:00|福建 | 查看全部
oslo里,怎么才能设置呢,谢谢
马红虎 Lv.8 发表于 2010-1-8 17:59:33|广东 | 查看全部
可以直接设置啊,zemax怎么设置
