[供应] RFD产品目录及价目表
2.2k 0
发表于 2010-10-7 12:55:35|广东 | 查看全部 阅读模式
大家好,我司代理销售美国RF产品,有需要请联系我。联系人:杨小姐0755-86173841/18818798007,e-mail:yhj712123@126.com msn:yangzhuo712@hotmail.com.skype:yangzhuo888
RF产品销售价目表
nRF24LE1 Modules
RFD21731         90 pieces per tray, 540 pc per box.        Standard Item
nRF24LE1 Module 15x15x3mm with Chip Antenna, No pre-loaded code, user writes their own code, CE
Quantity/数量        50000        25000        10000        5000        2500        1000        500        250        100        50        25        1
sales/销售价        ¥61.95         ¥63.76         ¥65.84         ¥68.00         ¥70.42         ¥74.65         ¥76.90         ¥77.07         ¥78.08         ¥79.40         ¥82.95         ¥90.46
RFD21732        90 pieces per tray, 540 pc per box.        Standard Item
Same as RFD21731, except it includes the 32 KHz micro size crystal used for deep ULP precision timing.
sales/销售价        ¥77.41         ¥79.75         ¥82.25         ¥85.02         ¥88.04         ¥91.32         ¥96.08         ¥96.60         ¥98.50         ¥99.27         ¥102.99         ¥113.01
RFD21733        90 pieces per tray, 540 pc per box.        Standard Item
nRF24LE1 Module 15x15x3mm NO-Antenna, No pre-loaded code, user writes their own code, includes 32khz crystal, CE
RFD21734        90 pieces per tray, 540 pc per box. Standard Item        Standard Item
RFD21735        90 pieces per tray, 540 pc per box.        Standard Item
nRF24LE1 Module 15x15x3mm NO-Antenna, CE, Includes 8 Mode Serial and Switch Firmware (RFDP8)
nRF24LE1 Module Eval Boards
RFD21736        Requires Nordic nRFgo Starter Kit        Standard Item
sales/销售价        call        call        call        call        call        call        call        call        call        call        call        ¥640.05
RFD21737        Standard Item
RFD21733 Eval Board, FCC, CE, Includes 8 Mode Serial and Switch Firmware (2 are required for a complete system)
sales/销售价        call        call        call        call        call        call        ¥214.79         ¥247.88         ¥293.50         ¥360.03         ¥451.44         ¥640.05
RFD21738        Standard Item
RFD21735 Eval Board, CE, Includes 8 Mode Serial and Switch Firmware & WIRE ANTENNA (2 are required for a complete system)
RFD21739        Standard Item
RFD21735 Eval Board, CE, Includes 8 Mode Serial and Switch Firmware & SMA Connector (2 are required for a complete system)
RFDANT with RFDP8 built-in.
RFD21743                                                FCC and CE                                Standard Item
nRF24LE1 RFDANT radio module with 11 pin cable and connector, FCC, CE, Includes 8 Mode Serial and Switch Firmware (RFDP8)
sales/销售价        call        call        call        call        call        call        ¥366.85         ¥381.54         ¥396.23         ¥410.92         ¥425.61         ¥440.29
RFD21773        Eval Board                                        FCC and CE                                Standard Item
RFD21743 Eval Board, FCC, CE, Includes 1 RFD21743, with RFDP8 firmware.
sales/销售价        call        call        call        call        call        call        ¥519.26         ¥562.90         ¥616.03         ¥687.83         ¥793.07         ¥971.40
RFD21742                                                        CE ONLY                        Standard Item
nRF24LE1 RFDANT radio module with 11 pin cable and connector, CE, Includes 8 Mode Serial and Switch Firmware (RFDP8
sales/销售价        call        call        call        call        call        call        ¥366.85         ¥381.54         ¥396.23         ¥410.92         ¥425.61         ¥440.92
RFD21772        Eval Board                                                CE ONLY                        Standard Item
RFD21742 Eval Board, CE, Includes 1 RFD21742, with RFDP8 firmware.
sales/销售价        call        call        call        call        call        call        ¥519.26         ¥563.07         ¥616.03         ¥687.83         ¥794.62         ¥971.40
RFDANT nRF24LE1 (no code) customer writes their own code.
RFD21741        Standard Item
ItemnRF24LE1 RFDANT radio module with 11 pin cable and connector, No pre-loaded code, user writes their own code, CE
sales/销售价        call        call        call        call        call        call        ¥371.17         ¥381.54         ¥396.23         ¥410.92         ¥425.61         ¥440.29
RFD21764        Requires Nordic nRFgo Starter Kit Eval Board        Standard Item
RFD21741 nRFgo Eval board, plugs into the Nordic nRFgo Eval Kit Board. (2 are required for a complete system), Includes 1 RFD21741
sales/销售价        call        call        call        call        call        call        call        call        call        call        call        ¥971.40
nRF24L01P Modules
RFD21712        Standard Item
nRF24L01P PCB Antenna Module, 2x4 header, HC49 SMT Crystal, CE.
sales/销售价        ¥24.02         ¥26.18         ¥30.17         ¥35.25         ¥42.94         ¥55.21         ¥78.97         ¥82.86         ¥88.82         ¥95.40         ¥106.01         ¥120.70
RFD21711        Standard Item
nRF24L01P SMA Module, 2x4 header, Micro SMT crystal.
sales/销售价        ¥48.38         ¥52.44         ¥60.13         ¥70.59         ¥85.88         ¥110.42         ¥157.94         ¥165.80         ¥177.72         ¥190.18         ¥211.94         ¥241.32
