[分享]我写的一个绘出相对亮度曲线的宏
3.4k 4
发表于 2003-7-23 17:00:00|浙江 | 查看全部 阅读模式
[10]!*****************************************************************************
! Sequence:   RELI.SEQ
! Purpose:   Macro to plot Relative illumination vs. Fileds
! Syntax:    in RELI
! Notes:    This macro uses and overwrites buffer B0.
! Author:    Doffey     Date: 2003-07-15
! History:   2003-07-15
lcl num ^numfld ^i ^j
lcl num ^fld(25) ^reli(25)
lcl str ^dim
lcl num ^maxfld
ver n
out n
^numfld == (num f)
if (typ fld)=ANG
  ^maxfld == (yan f^numfld)
else if (typ fld)=OBJ
  ^maxfld == (yob f^numfld)
else if (typ fld)=IMG
  ^maxfld == (yim f^numfld)
else if (typ fld)=RIH
  ^maxfld == (yri f^numfld)
else
  ^maxfld == 0
end if
^f==’f’
save
del fa
for ^i 1 20
ins f^i+1
^f==concat(^f,num_to_str(^i+1))
in cv_macro:cvsetfield Y ^i*^maxfld/20 $f
^f==’f’
end for
^numfld == (num f)
for ^i 1 ^numfld
  if (typ fld)=ANG
    ^fld(^i) == (yan f^i)
    ^fld(^i) == (yob f^i)
    ^fld(^i) == (yim f^i)
    ^fld(^i) == (yri f^i)
  else
    ^fld(^i) == 0
  end if
end for
out n
BUF DEL B0 ! clear B0 buffer
BUF YES  ! turn on output buffer to collect output
tra
go
BUF NO  ! turn off output buffer
BUF FND RELATIVE ILLUM:      ! find first occurrence
for ^i 1 ^numfld
^reli(^i) == (buf.num ic jc+4)/100 ! ic updated by each BUF FND
BUF FND               ! find next occurrence
end for
out y
wri Calculating the Relative Illumniation...
wri
wri FieldRelative Illumination
for ^i 1 ^numfld
wri Q’dd.ddd’ ’dd.ddd’ ^fld(^i) ^reli(^i)
end for
out n
! plot the MTF vs Field curves using UGR
ugr
tit substr((tit),1,40)
if (dim)=I
  ^dim ==  (inches)
else if (dim)=M
  ^dim ==  (mm)
else if (dim)=C
  ^dim ==  (cm)
else
  ^dim ==
end if
if (typ fld)=ANG
  xla FIELD ANGLE
  xla concat(OBJECT HEIGHT,^dim)
  xla concat(IMAGE HEIGHT,^dim)
  xla concat(REAL IMAGE HEIGHT,^dim)
else
end if
yla RELATIVE ILLUMINATION
xax 0   ! x and y cross at zero
yax 0
ymi 0   ! MTF range 0-1 by 0.1
yma 1.0
yde 0.1
yfo f 1  ! number formats for labels
xfo f 2
! create data point sets
dpo ’Relative Illumination’
spl 1 blu
for ^i 1 ^numfld
^fld(^i) ^reli(^i)
end for
end
go
wri
res
ver y
OUT YES
回复|共 4 个
toto Lv.6 发表于 2003-7-24 16:21:00|湖南 | 查看全部
[分享]我写的一个绘出相对亮度曲线的宏
不错
ariston0088 Lv.8 发表于 2003-8-16 20:27:00|广东 | 查看全部
[分享]我写的一个绘出相对亮度曲线的宏
不错,显示的范围比设计像高大,有没有办法让它们一致啊?
redflag 楼主Lv.14 发表于 2003-8-17 00:56:00|浙江 | 查看全部
[分享]我写的一个绘出相对亮度曲线的宏
你可以看本坛的我写的另外一个贴子,是我改进了的。你可以试一下
redflag 楼主Lv.14 发表于 2003-8-17 00:57:00|浙江 | 查看全部
[分享]我写的一个绘出相对亮度曲线的宏
http://bbs.oecr.com/cgi-bin/topic.cgi?forum=24topic=40show=0
