请告诉我H4和M2是一种镀膜材料?用在哪些光学薄膜上?谢谢了!!
4.5k 8
deveitu 发表于 2004-6-4 00:55:00|广东 | 查看全部 阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
回复|共 8 个
coatingli Lv.10 发表于 2004-6-4 01:10:00|广东 | 查看全部
Substance H1 highly refractive Patinal®
Granules, about 1.0-1.6 mm 1.16004
Tablets, about 1 g, 10 x 3.5 mm1.11611
Tablets, about 6 g, 14 x 9.5 mm1.13723
Discs, about 6 g, 17.5 x 5.4 mm1.13069
Refractive index
2.1 at 500 nm
Transmission range
360 - 7000 nm
Evaporation temperature2200 - 2400 °C
Evaporation sourcee-beam, W
ApplicationCoatings with high refractive index, multilayers
Product informationOn Request
In the description of tablets or discs, the first parameter is always the diameter, and the second the thickness
coatingli Lv.10 发表于 2004-6-4 01:12:00|广东 | 查看全部
Substance H2 highly refractive Patinal®
Granules, about 1-2.5 mm 1.16714
Granules, about 1-4 mm 1.16413
Refractive index
2.1 at 500 nm
Transmission range
400 - 5000 nm
Evaporation temperature2000 - 2200 °C
coatingli Lv.10 发表于 2004-6-4 01:13:00|广东 | 查看全部
Substance H4 highly refractive Patinal®
Granules, about 0.1-2 mm 1.15591
Granules, about 1-4 mm1.08332
Refractive index
2.1 at 500 nm
Transmission range
360 - 7000 nm
Evaporation temperature2200 - 2300 °C
ApplicationHighly refractive layers on glass and plastics
coatingli Lv.10 发表于 2004-6-4 01:14:00|广东 | 查看全部
Substance M2 medium refractive Patinal®
Granules, about 0.1-2 mm1.08302
Granules, about 1-4 mm 1.09941
Refractive index
1.7 at 500 nm
Transmission range
210 - 10000 nm
ApplicationMedium refractive layers on glass and plastics
coatingli Lv.10 发表于 2004-6-4 01:16:00|广东 | 查看全部
Substance H5 highly refractive Patinal®
Granules, about 1-4 mm1.08304
Refractive index
2.2 at 500 nm
Transmission range
350 - 7000 nm
Evaporation temperatureabout 2100 °C
Evaporation sourcee-beam, Mo
deveitu 楼主 发表于 2004-6-4 01:19:00|广东 | 查看全部
提示: 作者被禁止或删除 内容自动屏蔽
yin99 发表于 2004-6-4 03:10:00|安徽 | 查看全部
提示: 作者被禁止或删除 内容自动屏蔽
mxbplayboy Lv.7 发表于 2011-5-15 18:07:23|广东 | 查看全部
学习中!!!!
