[供应] Provide Intematix’s Remote Phosphor for LED lamp
2.3k 0
发表于 2013-3-17 10:27:16|广东 | 查看全部 阅读模式
Intematix delivers remote-phosphor optics family.
Remote Phosphor 远程荧光粉
Remote phosphor technology is another method you can take in creating your LED lighting application. The technology of remote phosphor light source element is achieved by bonding phosphor to a substrate, instead of incorporating it into the LED die package. Combining the remote phosphor plate with Royal Blue LEDs, and a mixing chamber, white light can be achieve with no visible point sources. This approach provides a low glare system capable or higher system efficiency, increase reliability and less color shift over time.
The Intematix ChromaLit remote phosphor light source will change the way you approach solid-state lighting design. ChromaLit offers beautiful light quality with unprecedented design freedom, color control, system flexibility and efficiency. ChromaLit is ideal for the most efficient and innovative lighting system designs.
Compared to conventional LED designs, where blue chips are coated with a phosphor compound, the ChromaLit Collection leverages a phosphor composite separated from the blue LED energy source. This architecture provides unparalleled design freedom, more efficient manufacturing processes, exceptional light quality and up to 30 percent higher system efficacy.
If you are interested, please contact Intematix photonics (Shenzhen) Co. Ltd. Gunther Liu,139-2744-3410. 请联系英特美光电刘先生,QQ,147-495-300.
Features & Benefits
1.        Omni-directional light distribution
2.        Glare-free LED light bulb design
3.        High color quality and color consistency
4.        Consistent color matching
5.        Unprecedented design freedom for solid state lighting products and systems
6.        Streamlined supply and production of LED lighting systems
7.        Up to 30% higher system efficacy compared to conventional LED lighting designs
Applications
1.        LED retrofit light bulbs
2.        Portable consumer lighting
3.        Downlights
4.        Wall sconces
5.        Pendants
6.        Chandelier and other decorative applications
7.        Appliances
8.        Task lighting
9.        High bay
10.        Panel lighting
11.        Spots and modules
12.        Modular shapes for linear lighting
Remote phosphor Technology
The ChromaLit™ Solution
ChromaLit leverages a phosphor composite precisely layered onto a substrate, separated from the blue LED energy source. The independent phosphor emits light when excited by blue light. Because the phosphor has been separated from the energy source and can now be made in any shape and any color, unidirectional light, hot spots, inconsistency and design limitations are no longer SSL challenges.
Unprecedented Design Freedom
The ChromaLit collection implements precision optics manufacturing and Intematix’s cutting-edge phosphor technology to provide lighting manufacturers with the capability to create previously unimaginable lighting systems in any shape and any color. Completely customizable in geometry, color temperature, CRI and substrate material, ChromaLit products offer flexibility and creative opportunities never before seen in luminaires. Uniform, curvilinear and three-dimensional lighting designs are now made possible where challenges existed with conventional LED approaches.
Brilliant Light Quality
Design with ChromaLit to harness a glare-free, diffuse light source and create consistent, high-quality light across multiple fixtures. Unique patterns enhance color rendering, and Intematix’s proprietary technology enables stable phosphor performance over the module’s lifetime and color-consistent, uniform luminaires.
Process Problems Solved
The interchangeability of ChromaLit simplifies binning management and reduces inventory of luminaires of wide spectral range. ChromaLit systems easily achieve multiple color specifications without replacing the entire luminaire. One standardized LED energy source can power multiple CCT, CRI and R9 requirements by simply replacing the ChromaLit, so one blue LED energy supply can be stocked alongside compact and easily swappable ChromaLit. As blue LEDs continue to improve in efficacy, the same ChromaLit can be easily integrated into new systems.
Unparalleled Lifetime Efficacy
ChromaLit offers up to 30 percent higher system efficacy than conventional LED lighting systems by operating at a lower temperature, maximizing photon extraction and removing the diffuser. By relocating the light production process away from the energy source, the ChromaLit architecture produces significantly more light per input power, increases LED package lifetime and reduces LED chip junction temperature. ChromaLit system designs can take advantage of fewer LEDs, smaller heat sinks, higher LED drive currents and reduced energy usage.
Future Possibilities
Our labs are continually developing new materials and improved processes. In the future, these advances will bring:
Improved optical control
Extended color temperature and CRI options
Diverse environmental viability
Specified shapes and sizes
Three major parts
Royal-Blue LEDs, Mixing chamber and Remote phosphor light source element are top three important parts of LED lamp.
ChromaLit Partners
When designing a remote phosphor system, there are three critical questions to ask yourself:
What color and shape of light do I need?
Which blue LED will provide optimal efficiency and light output?
Which mixing chamber approach suits my application best?
ChromaLit has color and shape covered with our high performance remote phosphor components (see our ChromaLit product selector guide and datasheet for more info). For the others, our partners offer focused solutions.
Blue LED Selection
ChromaLit is blue LED agnostic, allowing you to use any preferred blue LED. Still, more efficient and higher performing blue LEDs will greatly enhance the remote phosphor system.
Philips Lumileds Lighting Company
Philips Lumileds Lighting Company recently announced improvements to the LUXEON Rebel ES royal blue. Because of their high efficacy, the LUXEON LEDs enable optimized solutions when matched with our efficient ChromaLit phosphor components. Learn about LUXEON Rebel ES royal blue LEDs performance details.
OSRAM Opto Semiconductors
The OSLON® SSL 80 and 150 from OSRAM Opto Semiconductors offer a new and innovative way of maximizing the efficiency of your lighting products. As the first on the market of their kind, these remarkably compact LEDs offer beam angles optimized for use with lenses and reflectors. Learn about OSLON SSL deep blue performance details.
Mixing Chamber Partners
When it comes to the mixing chamber, reflectivity is key. Other considerations include shape, temperature, and method of application. The following suppliers offer materials to ensure advantageous light extraction. Contact suppliers for further technical details.
Furukawa
Furukawa produces a micro cell - polyethylene terephthalate (MC-PET), a microfoamed material with typical 10 micron feature size. Performance is rated at 99% total reflection and has a maximum temperature rating of 177°C.
WhiteOptics
WhiteOptics White97 film is a high density polyethylene material with a UL Relative Thermal Index of 100C/110C and a deformation temperature of 124°C. The material can be provided in rolls, die cut and thermoformed shapes with and without adhesive backing and has a reflectivity of 97.4% at 550nm.
Light Beam
Light Beam provides PolarKote, a reflective paint that can be applied to the mixing chamber. Materials are listed with reflectance levels of 90-97%, which for coated materials depends on the thickness applied and surface texture.
System Integration
Where can I go for integration assistance?
The ChromaLit architecture offers design freedom at every level. Integrators can assist in design and sourcing of quality components.
Intelligent LED Solutions
iLS (Intelligent LED Solutions), a leading solutions provider and distributor, connects you to the best technical and commercial expertise in the LED marketplace. iLS draws on world leading quality LEDs from Osram Opto Semiconductors and combines them with other quality components, materials and services to provide the LED solution you want. ILS has the expertise and experience to develop, design, manufacture and supply solid state lighting assemblies, LED light engines, LED light sources, etc to meet your requirements.
Specification
以下为所有ChromaLit的规格和价目表(包括产品型号,详细资料,产品数据,Datasheet,应用领域,应用范围和价格表)。我们将会尽我们最大的努力配合您进行新产品开发,协助客户解决新光源、新灯具开发过程中的一切问题。
Intematix ChromaLitThe ChromaLit 2D family offers 110 standard options in optimal shapes for a wide range of lighting applications. These 110 standard options can be viewed in the Intematix Product Selector Guide.
ChromaLit 圆形荧光产品 原型远程阳光房,圆形远程荧光粉 Remote phosphor ,圆片荧光粉层
部件编号 应用示例 典型流明输出 (lm)1 尺寸(mm) 直径 (in.) CCT (K) CRI Lm/Wrad 2 价格                (250件以上的订单请来电询价)                 ≥ 单件 ≥ 10件 50至250件
CL-827-R23-PC    单个 LED 110-200 22.5 0.9 2700 80 180 $0.93 $0.79 $0.66
CL-927-R23-PC    2700 90 160 $1.02 $0.86 $0.72
CL-830-R23-PC    3000 80 200 $0.85 $0.72 $0.60
CL-930-R23-PC    3000 90 165 $0.97 $0.82 $0.69
CL-835-R23-PC    3500 80 205 $0.76 $0.65 $0.54
CL-840-R23-PC    4000 80 210 $0.68 $0.57 $0.48
CL-750-R23-PC    5000 70 230 $0.59 $0.50 $0.42
CL-827-R34-PC    聚光灯 220-400 34.0 1.3 2700 80 180 $1.58 $1.34 $1.13
CL-927-R34-PC    2700 90 160 $1.73 $1.46 $1.23
CL-830-R34-PC    3000 80 200 $1.44 $1.22 $1.02
CL-930-R34-PC    3000 90 165 $1.65 $1.40 $1.18
CL-835-R34-PC    3500 80 205 $1.29 $1.10 $0.92
CL-840-R34-PC    4000 80 210 $1.15 $0.97 $0.82
CL-750-R34-PC    5000 70 230 $1.01 $0.85 $0.72
CL-827-SR-PC    射灯 440-800 45.0 1.8 2700 80 180 $2.58 $2.19 $1.84
CL-927-SR-PC    2700 90 160 $2.82 $2.39 $2.01
CL-830-SR-PC    3000 80 200 $2.35 $1.99 $1.67
CL-930-SR-PC    3000 90 165 $2.70 $2.29 $1.92
CL-835-SR-PC    3500 80 205 $2.11 $1.79 $1.51
CL-840-SR-PC    4000 80 210 $1.88 $1.59 $1.34
CL-750-SR-PC    5000 70 230 $1.64 $1.39 $1.17
CL-827-LR-PC    730-1300 61.5 2.4 2700 80 180 $4.47 $3.78 $3.18
CL-927-LR-PC    2700 90 160 $4.81 $4.08 $3.43
CL-830-LR-PC    3000 80 200 $4.01 $3.40 $2.85
CL-930-LR-PC    3000 90 165 $4.61 $3.91 $3.28
CL-835-LR-PC    3500 80 205 $3.61 $3.06 $2.57
CL-840-LR-PC    4000 80 210 $3.21 $2.72 $2.28
CL-750-LR-PC    5000 70 230 $2.81 $2.38 $2.00
CL-827-R75-PC    1100-2000 75.0 3.0 2700 80 180 $6.03 $5.11 $4.29
CL-927-R75-PC    2700 90 160 $6.58 $5.58 $4.68
CL-830-R75-PC    3000 80 200 $5.48 $4.65 $3.90
CL-930-R75-PC    3000 90 165 $6.30 $5.34 $4.49
CL-835-R75-PC    3500 80 205 $4.93 $4.18 $3.51
CL-840-R75-PC    4000 80 210 $4.39 $3.72 $3.12
CL-750-R75-PC    5000 70 230 $3.84 $3.25 $2.73
CL-827-R100-PC    2200-4000 100.0 3.9 2700 80 180 $8.76 $7.36 $6.41
CL-927-R100-PC    2700 90 160 $9.56 $8.03 $7.00
CL-830-R100-PC    3000 80 200 $7.96 $6.69 $5.83
CL-930-R100-PC    3000 90 165 $9.16 $7.69 $6.70
CL-835-R100-PC    3500 80 205 $7.17 $6.02 $5.25
CL-840-R100-PC    4000 80 210 $6.37 $5.35 $4.66
CL-750-R100-PC    5000 70 230 $5.58 $4.68 $4.08
CL-827-R135-PC    射灯 3600-6600 135.0 5.3 2700 80 180 $14.60 $12.27 $10.69
CL-927-R135-PC    2700 90 160 $15.93 $13.38 $11.66
CL-830-R135-PC    3000 80 200 $13.27 $11.15 $9.72
CL-930-R135-PC    3000 90 165 $15.27 $12.82 $11.17
CL-835-R135-PC    3500 80 205 $11.95 $10.04 $8.75
CL-840-R135-PC    4000 80 210 $10.62 $8.92 $7.77
CL-750-R135-PC    5000 70 230 $9.29 $7.81 $6.80
CL-830-R215-PC    高棚灯 14000-16500 215.0 8.5 3000 80 200 $37.17 $31.22 $27.21
CL-840-R215-PC    4000 80 210 $33.45 $28.10 $24.49
CL-750-R215-PC    5000 70 230 $29.73 $24.98 $21.77
ChromaLit 线条形荧光产品部件 长条形远程荧光粉 Remote phosphor ,线性荧光粉远离层,线形荧光粉层
编号 应用示例 典型流明输出 (lm)1 尺寸 L x W (mm) 尺寸 L x W (in.) CCT (K) CRI Lm/Wrad2 价格        (250件以上的订单请来电询价) ≥ 单件 ≥ 10件 50至250件
CL-827-L225-PC    工作照明/线条形照明/平板形照明 950-2400 305.0 x 22.5 12.0 x 0.9 2700 80 180 $4.61 $4.01 $3.58
CL-830-L225-PC    3000 80 200 $7.11 $6.03 $5.06
CL-835-L225-PC    3500 80 205 $6.40 $5.42 $4.56
CL-840-L225-PC    4000 80 210 $5.69 $4.82 $4.05
CL-750-L225-PC    5000 70 230 $4.98 $4.22 $3.54
CL-830-L125-PC    950-1400 305.0 x 12.5 12.0 x 0.5 3000 80 200 $4.14 $3.50 $2.94
CL-835-L125-PC    3500 80 205 $3.73 $3.15 $2.65
CL-840-L125-PC    4000 80 210 $3.31 $2.81 $2.36
CL-750-L125-PC    5000 70 230 $2.90 $2.45 $2.06
*产品性能基于参考设计。产品规格会有所变化。
1. 标准流明输出根据推荐使用的典型蓝色 LED 辐射瓦特估算
2. Lm/Wrad: 每单位以辐射瓦特计的蓝色 LED 输入功率的流明输出
ChromaLit 方形荧光产品 正方形远程荧光粉 Remote phosphor ,方片荧光粉远离薄膜
部件编码 应用示例 典型流明输出 (lm)1 直径 (mm) 直径 (in.) CCT (K) CRI Lm/Wrad 2 价格
(250件以上的订单请来电询价)
≥ 单件 ≥ 10件 50至250件
CL-827-S21-PC    单个 LED 110-220 21.0 x 21.0 0.8 x 0.8 2700 80 180 $0.93 $0.79 $0.66
CL-927-S21-PC    2700 90 160 $1.02 $0.86 $0.72
CL-830-S21-PC    3000 80 200 $0.85 $0.72 $0.60
CL-930-S21-PC    3000 90 165 $0.97 $0.82 $0.69
CL-835-S21-PC    3500 80 205 $0.76 $0.65 $0.54
CL-840-S21-PC    4000 80 210 $0.68 $0.57 $0.48
CL-750-S21-PC    5000 70 230 $0.59 $0.50 $0.42
CL-827-S40-PC    射灯 440-800 40.0 x 40.0 1.6 x 1.6 2700 80 180 $2.58 $2.19 $1.84
CL-927-S40-PC    2700 90 160 $2.82 $2.39 $2.01
CL-830-S40-PC    3000 80 200 $2.35 $1.99 $1.67
CL-930-S40-PC    3000 90 165 $2.70 $2.29 $1.92
CL-835-S40-PC    3500 80 205 $2.10 $1.78 $1.49
CL-840-S40-PC    4000 80 210 $1.86 $1.58 $1.33
CL-750-S40-PC    5000 70 230 $1.64 $1.39 $1.17
CL-827-S55-PC    730-1300 55.0 x 55.0 2.2 x 2.2 2700 80 180 $4.46 $3.78 $3.17
CL-927-S55-PC    2700 90 160 $4.81 $4.08 $3.43
CL-830-S55-PC    3000 80 200 $4.01 $3.40 $2.85
CL-930-S55-PC    3000 90 165 $4.61 $3.91 $3.28
CL-835-S55-PC    3500 80 205 $3.56 $3.02 $2.53
CL-840-S55-PC    4000 80 210 $3.09 $2.62 $2.20
CL-750-S55-PC    5000 70 230 $2.81 $2.38 $2.00
CL-827-S65-PC    射灯 1100-2000 65.0 x 65.0 2.6 x 2.6 2700 80 180 $6.03 $5.11 $4.29
CL-927-S65-PC    2700 90 160 $6.58 $5.58 $4.68
CL-830-S65-PC    3000 80 200 $5.48 $4.65 $3.90
CL-930-S65-PC    3000 90 165 $6.30 $5.34 $4.49
CL-835-S65-PC    3500 80 205 $4.93 $4.18 $3.51
CL-840-S65-PC    4000 80 210 $4.39 $3.72 $3.12
CL-750-S65-PC    5000 70 230 $3.84 $3.25 $2.73
CL-827-S95-PC    2200-4000 95.0 x 95.0 3.7 x 3.7 2700 80 180 $8.76 $7.36 $6.41
CL-927-S95-PC    2700 90 160 $9.56 $8.03 $7.00
CL-830-S95-PC    3000 80 200 $7.96 $6.69 $5.83
CL-930-S95-PC    3000 90 165 $9.16 $7.69 $6.70
CL-835-S95-PC    3500 80 205 $7.17 $6.02 $5.25
CL-840-S95-PC    4000 80 210 $6.37 $5.35 $4.66
CL-750-S95-PC    5000 70 230 $5.58 $4.68 $4.08
CL-827-S120-PC    3600-6600 120.0 x 120.0 4.7 x 4.7 2700 80 180 $14.60 $12.27 $10.69
CL-927-S120-PC    2700 90 160 $15.93 $13.38 $11.66
CL-830-S120-PC    3000 80 200 $13.27 $11.15 $9.72
CL-930-S120-PC    3000 90 165 $15.27 $12.82 $11.17
CL-835-S120-PC    3500 80 205 $11.95 $10.04 $8.75
CL-840-S120-PC    4000 80 210 $10.62 $8.92 $7.77
CL-750-S120-PC    5000 70 230 $9.29 $7.81 $6.80
CL-830-S200-PC    高棚灯 14000-16500 200.0 x 200.0 7.9 x 7.9 3000 80 200 $37.17 $31.22 $27.21
CL-840-S200-PC    4000 80 210 $33.45 $28.10 $24.49
CL-750-S200-PC    5000 70 230 $29.73 $24.98 $21.77
ChromaLit 平板形荧光产品 面形荧光粉膜,大面积荧光粉膜,平面型远程荧光粉 Remote phosphor
部件编号 应用示例 典型流明输出 (lm)1 尺寸 L x W (mm) 尺寸 L x W (in.) CCT (K) CRI Lm/Wrad 2 价格
(250件以上的订单请来电询价)
≥ 单件 ≥ 10件 50至250件
CL-827-P215-PC    定制 15000-27500 305.0 x 215.0 12.0 x 8.5 2700 80 180 $53.97 $47.03 $41.89
CL-927-P215-PC    2700 90 160 $58.87 $51.30 $45.70
CL-830-P215-PC    3000 80 200 $49.06 $42.75 $38.08
CL-930-P215-PC    3000 90 165 $56.42 $49.17 $43.79
CL-835-P215-PC    3500 80 205 $44.16 $38.48 $34.27
CL-840-P215-PC    4000 80 210 $39.25 $34.20 $30.47
CL-750-P215-PC    5000 70 230 $34.34 $29.93 $26.66
Intematix ChromaLit  - Ellipse, Candle, Dome
Intematix' also offers a wide range of 3D products, including the ChromaLit Ellipse, Candle and Dome remote phosphor light sources which enables brighter, more energy efficient LED bulbs and lighting fixtures by providing wide angle lighting distribution, improved light quality, and greater design freedom. They are offered in a variety of lumen levels for applications in indoor and outdoor general lighting, decorative and retrofit light bulb designs.
ChromaLit 烛光形荧光产品 蜡烛型远程荧光粉 Remote phosphor ,烛光型荧光粉膜
部件编号 应用示例 典型流明输出 (lm)1 最大直径 (mm) 高(mm) CCT (K) CRI Lm/Wrad 2 价格
≥ 单件 ≥ 250件 ≥ 1K件
CL-827-CAN15-PC    LED 改型灯/ 灯笼灯/ 吊灯 70-150 11.9 16.0 2700 80 165 $0.90 $0.73
CL-927-CAN15-PC    2700 90 140 $1.12 $0.91
CL-830-CAN15-PC    3000 80 185 $0.87 $0.70
CL-930-CAN15-PC    3000 90 150 $0.97 $0.78
CL-835-CAN15-PC    3500 80 190 $0.86 $0.69
CL-840-CAN15-PC    4000 80 195 $0.80 $0.65
CL-750-CAN15-PC    5000 70 220 $0.74 $0.60
CL-827-CAN30-PC    LED 改型灯/ 灯笼灯/ 吊灯 150-300 16.9 24.2 2700 80 165 $1.63 $1.32
CL-927-CAN30-PC    2700 90 140 $2.10 $1.70
CL-830-CAN30-PC    3000 80 185 $1.62 $1.31
CL-930-CAN30-PC    3000 90 150 $1.81 $1.46
CL-835-CAN30-PC    3500 80 190 $1.60 $1.29
CL-840-CAN30-PC    4000 80 195 $1.42 $1.15
CL-750-CAN30-PC    5000 70 220 $1.01 $0.81
CL-827-CAN40-PC    LED 改型灯/ 灯笼灯/ 吊灯 300-700 26.6 35.0 2700 80 165 $2.18 $1.76
CL-927-CAN40-PC    2700 90 140 $2.80 $2.26
CL-830-CAN40-PC    3000 80 185 $2.16 $1.74
CL-930-CAN40-PC    3000 90 150 $2.41 $1.94
CL-835-CAN40-PC    3500 80 190 $2.13 $1.72
CL-840-CAN40-PC    4000 80 195 $1.90 $1.53
CL-750-CAN40-PC    5000 70 220 $1.66 $1.34
ChromaLit 椭圆形荧光产品 椭球形远程荧光粉 Remote phosphor ,半椭圆荧光粉远离
≥ 单件 ≥ 250件 ≥ 1K件
CL-827-ELP30-PC    LED 改型灯/廊灯和景观照明/ 吊灯 200-350 15.3 26.5 2700 80 165 $1.63 $1.32
CL-927-ELP30-PC    2700 90 140 $2.10 $1.70
CL-830-ELP30-PC    3000 80 185 $1.62 $1.31
CL-930-ELP30-PC    3000 90 150 $1.81 $1.46
CL-835-ELP30-PC    3500 80 190 $1.60 $1.29
CL-840-ELP30-PC    4000 80 195 $1.42 $1.15
CL-750-ELP30-PC    5000 70 220 $1.01 $0.81
CL-827-ELP40-PC    LED 改型灯/廊灯和景观照明/ 吊灯 350-600 23.0 32.9 2700 80 165 $2.18 $1.76
CL-927-ELP40-PC    2700 90 140 $2.80 $2.26
CL-830-ELP40-PC    3000 80 185 $2.16 $1.74
CL-930-ELP40-PC    3000 90 150 $2.41 $1.94
CL-835-ELP40-PC    3500 80 190 $2.13 $1.72
CL-840-ELP40-PC    4000 80 195 $1.90 $1.53
CL-750-ELP40-PC    5000 70 220 $1.66 $1.34
CL-827-ELP60-PC    LED 改型灯/廊灯和景观照明/ 吊灯 550-850 26.3 40.4 2700 80 165 $3.06 $2.47
CL-927-ELP60-PC    2700 90 140 $3.94 $3.18
CL-830-ELP60-PC    3000 80 185 $3.04 $2.45
CL-930-ELP60-PC    3000 90 150 $3.39 $2.73
CL-835-ELP60-PC    3500 80 190 $3.00 $2.42
CL-840-ELP60-PC    4000 80 195 $2.67 $2.15
CL-750-ELP60-PC    5000 70 220 $1.89 $1.52
ChromaLit 圆顶形荧光产品 球形远程荧光粉 Remote phosphor ,球顶型荧光粉远离
部件编号 应用示例 典型流明输出 (lm)1 最大直径 (mm) 高 (mm) CCT(K) CRI 典型转换率 (Lm/Wrad)2 价格
≥ 单件 ≥ 250件 ≥ 1K件
CL-827-DOM15-PC    指示灯/ 景观照明/ LED 单灯应用 100-200 14.0 13.8 2700 80 165 $1.09 $0.88
CL-927-DOM15-PC    2700 90 140 $1.40 $1.13
CL-830-DOM15-PC    3000 80 185 $1.08 $0.87
CL-930-DOM15-PC    3000 90 150 $1.21 $0.97
CL-835-DOM15-PC    3500 80 190 $1.07 $0.86
CL-840-DOM15-PC    4000 80 195 $0.87 $0.70
CL-750-DOM15-PC    5000 70 220 $0.80 $0.65
CL-827-DOM40-PC    LED 改型灯管/ 吊灯/ 壁灯/ 顶灯 300-600 33.0 20.5 2700 80 165 $2.18 $1.76
CL-927-DOM40-PC    2700 90 140 $2.80 $2.26
CL-830-DOM40-PC    3000 80 185 $2.16 $1.74
CL-930-DOM40-PC    3000 90 150 $2.41 $1.94
CL-835-DOM40-PC    3500 80 190 $2.13 $1.72
CL-840-DOM40-PC    4000 80 195 $1.90 $1.53
CL-750-DOM40-PC    5000 70 220 $1.66 $1.34
CL-827-DOM60-PC    LED 改型灯管/ 吊灯/ 壁灯/ 顶灯 600-1000 42.0 26.1 2700 80 165 $3.26 $2.63
CL-927-DOM60-PC    2700 90 140 $4.21 $3.39
CL-830-DOM60-PC    3000 80 185 $3.24 $2.62
CL-930-DOM60-PC    3000 90 150 $3.62 $2.92
CL-835-DOM60-PC    3500 80 190 $3.20 $2.58
CL-840-DOM60-PC    4000 80 195 $2.85 $2.30
CL-750-DOM60-PC    5000 70 220 $2.02 $1.63
CL-827-DOM100-PC    LED 改型灯管/ 吊灯/ 壁灯/ 顶灯 1000-1600 55.0 34.1 2700 80 165 $5.44 $4.39
CL-927-DOM100-PC    2700 90 140 $7.01 $5.65
CL-830-DOM100-PC    3000 80 185 $5.40 $4.36
CL-930-DOM100-PC    3000 90 150 $6.03 $4.86
CL-835-DOM100-PC    3500 80 190 $5.33 $4.30
CL-840-DOM100-PC    4000 80 195 $4.75 $3.83
CL-750-DOM100-PC    5000 70 220 $3.36 $2.71
ChromaLit Contour(环形荧光粉层,环形荧光粉膜,能源之星型远程荧光粉 Remote phosphor ,新型远程荧光粉 Remote phosphor )
CL-827-CTR75-PC    LED 改型灯 1100 60 18.7 2700 80 185
CL-927-CTR75-PC    2700 90 150
CL-830-CTR75-PC    3000 80 195
CL-930-CTR75-PC    3000 90 160
CL-850-CTR75-PC    5000 80 210
CL-827-CTR100-PC    1600 25.6 2700 80 185
CL-927-CTR100-PC    2700 90 150
CL-830-CTR100-PC    3000 80 195
CL-930-CTR100-PC    3000 90 160
CL-850-CTR100-PC    5000 80 210
