[市场] The World''s only Super SMT Component Enclosure
3.0k 0
发表于 2014-4-22 14:20:04|辽宁 | 查看全部 阅读模式
[img=633,472][/img]Our Super SMT Component Enclosure is the world's only enclosure for electronic components storage, which has > 100 compartments for enclosing SMT components, such as chip resistors, capacitors, inductors, ICs, etc. This enclosure has 128 individually lidded compartments, all covered by a top cover. There is a foam pad under the top cover, which presses down all the 128 lids onto their closing positions, thus, they can tolerate strong vibration and shock without opening, so that the parts inside will never be leaked out.
On the bottom of the enclosure, it comes with 2 strips of rubber feet, they will lock into the 2 slots onthe top cover of another enclosure when stacking enclosures together.
On the top surface, there is a label area, in which a label can be placed or marks can be hand written, for identifying the internal contents of the enclosure.http://www.analogtechnologies.com/enclosure.html
