[技术] 基于自发辐射抑制的红外光机系统优化设计
3.1k 0
发表于 2015-7-10 17:29:06|湖北 | 查看全部 阅读模式
基于自发辐射抑制的红外光机系统优化设计
Optimized Design of Infrared Opto-Mechanical Systems Based on the Spontaneous Emission Suppression
下载全文
基于自发辐射抑制的红外光机系统优化设计.pdf (764.8 KB, 下载次数: 10)
作  者:周军 李娟 王庆丰 许敏达 张聪跃
Zhou Jun Li Juan Wang Qingfeng Xu Minda Zhang Congyue  (Beijing Institute of Remote Sensing Equipment, Beijing 100854, China)
机构地区:北京遥感设备研究所,北京100854
出  处:《光学学报》 EI CSCD 2015年第3期 278-285页,共8页
Acta Optica Sinica
摘  要:低背景探测的红外光机系统,目标信号很弱,系统自发辐射影响很大。指出了考虑系统自发辐射抑制的红外光机系统优化设计方法。从有效发射率和等效黑体辐射温度两方面比较了折反、同轴全反和离轴全反结构在自发辐射抑制方面的优劣,发现全反系统优于折反系统,离轴全反系统最优;从等效黑体辐射温度的变化,介绍了光机系统工作波段优化、结构优化设计和构件表面优化处理,发现甚长波探测在低背景下具有明显优势、光机结构表面高反和发黑合理布局效果更好;分析了制冷对光机系统抑制自发辐射的作用,发现制冷对自发辐射抑制作用明显,但制冷温度越低,效率越差,采取局部关键面制冷效果显著。
For the low background detecting infrared opto- mechanical systems, the signal is very weak and the spontaneous emission of the system has a large impact. This paper discusses the optimized design of infrared opto-mechanical systems based on the spontaneous emission suppression. The refraction-reflection system, coaxial reflection system and off- axis reflection system are compared on the spontaneous emission suppression in the way of effective emissivity and equivalent blackbody radiation temperature(EBRT). We find that the reflection system is better than refraction-reflection system and the off-axis reflection system is the best. From the change of equivalent blackbody radiation temperature, the paper introduces choosing the wavelength range, the optimized design of opto- mechanical structure and the surface processing. It is concluded that the even longer wavelength detecting has clearly advantage in the low background and it is better that the reflective surfaces and black surfaces has reasonable layout. The impact of refrigeration to the opto- mechanical systems suppressing the spontaneous emission is discussed. We find that refrigeration system can suppress spontaneous emission obviously, while the efficiency is worse when the refrigeration temperature is lower. So the crucial surfaces refrigeration can be adopted.
关键词:光学设计 自发辐射 等效发射率 等效黑体辐射温度 甚长波 制冷
optical design ; spontaneous emission ; effective emissivity ; equivalent blackbody radiation temperature ; even longer wavelength ; refrigeration ;
本帖被以下淘专辑推荐:
