[技术] Ф1.2m主镜光学加工中轴向支撑系统的补偿力分析计算
3.1k 0
发表于 2015-7-12 15:27:01|湖北 | 查看全部 阅读模式
Analysis and calculation for compensation force in axial support system in Ф1.2 m primary mirror optical fabrication
下载全文
Ф1.2m主镜光学加工中轴向支撑系统的补偿力分析计算.pdf (811.61 KB, 下载次数: 0)
作  者:王洪桥[1,2] 范斌[1] 吴永前[1] 刘海涛[1,2] 刘容[1,2]
Wang Hongqiao, Fan Bin, Wu Yongqian, Liu Haitao, Liu Rong( The Institute of Optics and Electronics the Chinese Academy of Sciences, Chendu 610209, China 2. University of Chinese Academy of Sciences, Beijing 100049, China)
机构地区:[1]中国科学院光电技术研究所,四川成都610209 [2]中国科学院大学,北京100049
出  处:《红外与激光工程》 EI CSCD 2014年第43卷第6期 1889-1893页,共5页
Infrared and Laser Engineering
摘  要:大镜面反射镜在加工过程中需要处理一些低阶的Zemike多项式面形中非旋转对称的面形残余量。这些面型残余量大大增加了加工的难度。提出利用主动支撑技术指导镜面面形的加工过程,降低加工难度。主要研究加工过程中应用主动支撑技术补偿某些低阶Zernike系数面形残差的技术方法。在轴向支撑系统中采用全浮动支撑方式对镜面面形进行控制,采用力作为控制变量的控制模式使镜面产生低阶Zemike多项式面形变化,进一步“修正”处理某些不满足合力为零和合力矩平衡的解。成功实现主动支撑补偿低阶Zemike系数项面形。最后通过Ansys—Workbench软件仿真验证该计算方法的可行性。
Dealing with some non-rotational symmetrical residual error in low-frequency Zemike polynomials surface is needed in the manufacture of large-reflecting mirror. These errors greatly increase the difficulty of processing. Propose to change the mirror surface for reducing the fabrication difficulty by active support technique. Study the method of compensating some non-rotational symmetrical residual error in low-frequency Zernike polynomials surface by active support technique. Firstly, apply the allfloating support method in axial support system to control the deformation of the mirror's surface. Then, apply force as the control variable in the system. Do the "correction" process on the solution which can not satisfy the principles of "Resultant equal to zero" and "Total torque equal to zero". Successfully achieve the compensation of low-frequency Zernike coefficient surface by active support technique. The results of simulation by Ansys-Workbench software prove the feasible.
关键词:主动支撑 薄镜 有限元分析
active support ; thin mirror ; FEA ;
本帖被以下淘专辑推荐:
