[技术] 355nm紫外激光抛光Al2O3陶瓷工艺的研究
4.3k 2
发表于 2015-7-12 18:32:15|湖北 | 查看全部 阅读模式
Study on polishing process of Al2O3 ceramic with 355nm ultraviolet laser
下载全文
355nm紫外激光抛光Al2O3陶瓷工艺的研究.pdf (1.34 MB, 下载次数: 3)
作  者:周敏 魏昕 谢小柱 胡伟
ZHOU Min, WEI Xin ,XIE Xiaozhu ,HU Wei ( Faculty of Electromechanical Engineering, Guangdong University of Technology, Guangzhou 510006, China)
机构地区:广东工业大学机电工程学院,广州510006
出  处:《激光技术》 CSCD 2014年第38卷第4期 556-560页,共5页
Laser Technology
基  金:国家自然科学基金资助项目(50675038;50805027);广东省自然科学基金资助项目(S2013010014070)
摘  要:紫外激光抛光Al2O3陶瓷可以有效地降低加工中的热影响区、防止微裂纹的产生。为了得到不同激光工艺参量(激光能量密度、扫描速率、扫描间隔)对Al2O3陶瓷抛光表面粗糙度的影响规律,采用单因素实验方法进行了355nm紫外激光抛光Al2O3陶瓷的工艺实验,获得了最优的工艺参量范围。结果表明,当激光能量密度为6J/cm2、扫描间隔为2μm、扫描速率为60mm/s时,抛光后分别获得了较小的表面粗糙度值。这一结果对获得的低粗糙度、高质量的Al2O3陶瓷抛光表面具有指导意义。
Al2O3 ceramic polished with 355nm ultraviolet laser could effectively reduce the heat affected zone in processing and prevent the formation of microcracks.In order to find the effects of different parameters(laser energy intensity,laser scanning velocity,laser scanning interval) on the surface roughness and the surface quality,a series of experiments were carried out with a single factor of the 355nm ultraviolet laser affecting the polishing result.The optimal technology parameters were obtained at last.The results show that relatively small surface roughness can be obtained under the conditions of 6J /cm2laser fluence,60mm /s laser scanning velocity and 2μm laser scanning interval.The study is helpful for getting low roughness and high quality of Al2O3 ceramic.
关键词:激光技术 激光抛光 激光能量密度 激光扫描速率 激光扫描间距 Al2O3陶瓷
laser technique ;laser polishing ;laser energy intensity ;laser scanning velocity ;laser scanning interval ;Al2O3 ceramic ;
本帖被以下淘专辑推荐:
回复|共 2 个
风轻扬 楼主Lv.10 发表于 2015-7-12 18:32:49|湖北 | 查看全部
用激光抛光可真是太牛了,大家一定要下载来看看。
riy2000 Lv.8 发表于 2015-11-12 11:23:23|云南 | 查看全部
