体视显微镜与CCD成像系统在高阶贝塞尔光束光斑测量中的应用
Application of stereomicroscope and CCD imaging system to spot size measurement of high-order Bessel beam
下载全文
体视显微镜与CCD成像系统在高阶贝塞尔光束光斑测量中的应用.pdf
(990.93 KB, 下载次数: 1)
作 者:陈姿言 吴逢铁 何西 沈栋辉
Chen Ziyan, Wu Fengtie, He Xi, Shen Donghui (Fujian Key Laboratory of Optical Beam Transmission and Transformation, College of Information Science & Engineering, Huaqiao University, Xiamen 361021, China)
机构地区:华侨大学信息科学与工程学院,福建省光传输与变换重点实验室,福建厦门361021
出 处:《强激光与粒子束》 EI CSCD 2014年第26卷第11期 27-32页,共6页
High Power Laser and Particle Beams
基 金:国家自然科学基金项目(61178015);福建省自然科学基金项目(2012J01278);泉州市科技重点项目资助课题(2014Z12)
摘 要:主要对光学测量仪器体视显微镜与CCD成像系统在高阶贝塞尔光束光斑测量中的应用进行分析,通过以非相干LED绿光经过螺旋相位板和轴棱锥产生的高阶贝塞尔(Bessel)光束为例,模拟出沿轴向不同距离处的截面光强分布图,并与相应的实验参数(如:最大无衍射距离、中心暗斑直径等)进行比较.实验结果表明,体视显微镜与CCD成像系统的测量结果相吻合,但是体视显微镜测量误差较大会影响测量结果的准确度.
This article mainly analyzed the application of optical measuring instruments,stereomicroscope and CCD imaging system to the spot measurement of high-order Bessel beam.By taking the high-order Bessel beam which is generated when incoherent LED green light is passing through the spiral phase plate and axicon as an example,we simulated the cross-section intensity distribution at different distances along the axial direction,and it is compared to corresponding experimental parameters,such as maximum non-diffracting distance,central spot diameter etc.The experimental result shows that the measurement results of stereomicroscope and CCD imaging system are in good agreement,but there are different merits and demerits between these two instruments,and the measurement error of stereomicroscope will affect the accuracy of measurement results.
关键词:体视显微镜 CCD成像系统 微尺寸光斑测量 高阶贝塞尔光束
stereomicroscope ; CCD imaging system ; micro sized spot measurement ; high-order Bessel beam ; |
