[技术] 太阳能辅助燃气锅炉制取蒸汽在工程中的应用
2.6k 0
发表于 2015-7-13 22:23:27|湖北 | 查看全部 阅读模式
Application of Solar Assisted Gas Boiler to Produce Steam in Engineering
下载全文
太阳能辅助燃气锅炉制取蒸汽在工程中的应用.pdf (453.45 KB, 下载次数: 0)
作  者:吕莉[1] 张红兵[2]
LV Li, ZHANG Hong-bing ( 1.Xuzhou Hanyi Architectural Design Co. Ltd., Xuzhou 221006, China; (2.Ji'nan Municipal Engineering Design & Research Institute (Group) Co.Ltd., Jinan 250101, China)
机构地区:[1]徐州瀚艺建筑设计有限公司,江苏徐州221006 [2]济南市市政工程设计研究院(集团)有限责任公司,济南250101
出  处:《工程建设与设计》 2015年第4期 77-79页,共3页
Construction & Design for Project
摘  要:提出太阳能辅助燃气锅炉制取生产蒸汽的新模式,结合实际工程案例着重讲述了系统组成及设备的计算选型,同时通过耗热量计算得出此种模式比直接采用燃气锅炉节省燃气消耗10%左右,有效减少常规化石能源消耗,为太阳能辅助燃气锅炉联合热源系统的推广应用提供了一种新方法。
This paper proposes a new model of solar assisted gas boiler steam production preparation, combined with the practical engineering case focuses on the selection and calculation of system components and equipment, at the same time through the heat loss calculated directly using gas boiler than the gas consumption is reduced 30%, effectively reduce the conventional fossil energy consumption,and provides a new method for the popularization and application of combined solar assisted heat source system of gas boiler.
关键词:能源联合利用模式 太阳能与建筑一体化 燃气锅炉
model of joint use of energy ; the integration of solar energy and building ; gas boiler ;
本帖被以下淘专辑推荐:
