[公告]
1.4k 1
发表于 2006-6-30 21:27:00|北京 | 查看全部 阅读模式
Do you need a precise, but economic spectral resolving instrument for lamp measurement, color check or spectral transmission test of liquid samples?
- -So take a look on our specbos series!- -
The specbos series relies on the proved JETI principles small, robust and easy to use. JETI offers a serie specbosxx01 wirh USB Interface (download data sheet 256kB).
There are available several models specially designed for different applications:
SpectrometerSpectroradiometerSpectrophotometerSpectrocolorimeter
All instruments are based on the same miniature spectrograph, which guarantees low stray light and a high dynamics.
At our Download-Section Application Notes you find an Application Note with the Firmware Interface Commands and an Application Note with Install hints for our specbos serie xx01.
General technical data
specbos xx01
Wavelength Range380 .. 760 nm for VIS versions
250 .. 500 nm for UV version
Optical Resolution6 or 9nm
Electronic resolution16 bit (15 bit used)
Dynamics104
Stray light 10-3 (ASTM E387, GG495, 4mm, l = 420nm/ 630nm)
Wavelength accuracy± 0.5 nm
Integration time5ms .. 60s
Size140 mm x 58 mm x 34 mm
InterfacesUSB2.0 fullspeed (12Mbit/sec)
Included accessoriesApplication specific Windows software
Operation manual
PC cable
Application specific accessories
Transport box
luxiaojun 楼主Lv.6 发表于 2006-6-30 21:31:00|北京 | 查看全部
自己坐沙发
哈哈
上面是我们代理的德国JETI公司的产品简介,如有意向请登录WWW.JETI.COM网站,并向我公司索取报价,谢谢!
本公司EMAIL地址为:BJTYH@126.COM
价格相当有竞争力喔!
