提供OSRAM大功率LED
1.9k 1
发表于 2007-11-15 11:04:06|广东 | 查看全部 阅读模式
我们提供OSRAM的大功率照明LED,主要有0.5W,1W,3W,12W,18W
LWG6SP    0.5W 白光   30lm/W    零售价: U$1/pcs
LWW5SM    1W 白光   45~71lm/W    零售价: U$2/pcs
LWW5SN    3W 白光   30lm/W    零售价: U$2.7/pcs
LWW5SM.pdf
469.04 KB, 下载次数: 6, 下载积分: 光电贝 -1 元
LWW5SN.pdf
592.61 KB, 下载次数: 4, 下载积分: 光电贝 -1 元
LWG6SP.pdf
461.42 KB, 下载次数: 4, 下载积分: 光电贝 -1 元
penhh163com 楼主Lv.7 发表于 2007-11-16 13:03:04|广东 | 查看全部
OSRAM推出90lm/W的大功率LED
OSRAM 推出最新的1W大功率LED,
LUWW5SM   1W 白光   90lm/W
LUW W5SM-JYKY-5P7R
white
52.000 ... 97.000ΦV (mlm)
22.000 (typ.)IV (mcd)
LUW W5SM-JYKY-5D6E
white
22.000 (typ.IV (mcd)
LUW W5SM-JYKY-7D8E
white
Features
•package: white SMD package, colorless clear silicone resin; chip level conversion
•typical Luminous Flux: 66lm at 350 mA
•feature of the device: high efficient lightsource at low space
•color coordinates: x=0.31, y=0.32 acc. to CIE1931(white)
•typ. color temperature: 6500K
•viewing angle: Lambertian Emitter (120°)
•technology: ThinGaN®
•optical efficiency: 60lm/W
•grouping parameter: luminous flux, colorcoordinates
•assembly methods: suitable for all SMTassembly methods
•soldering methods: IR reflow soldering
•preconditioning: acc. to JEDEC Level 4
•taping: 24mmtape with 800/reel, ø180mm
•ESD-withstand voltage: up to 2kV acc. to JESD22-A114-B
Applications
•exterior and interior automotive lighting (e.g.frontlight)
•Flashlight
•backlighting (illuminated advertising, general lighting)
•reading lamps (aircraft, car, bus)
•substitution of micro incandescent lamps
•indoor and outdoor commercial and residential architectural lighting
•display backlight where high brightness is required e.g. TFT
•decorative and entertainment lighting
•signal and symbol luminaire for orientation
•marker lights (e.g. steps, exit ways, etc.)
