2008-2-25 16:37:55 | 显示全部楼层 | 阅读模式
81689A 可调光源模块出售
81689A 可调范围:1525 nm to 1575 nm
www.starbluecn.com Starblue Corporation USA shenzhen Branch
周先生 0755-26714896 13682680312 support@starbluecorp.com
我公司特价供应81689A 可调光源模块, 成色不错,质量可靠,价格适中,欢迎前来洽谈选购.
81689A Tunable Light Source Module
Description:
This module features:
Continuous sweep through full wavelength range
Mode-hop free tuning over full wavelength range
This module has the following specifications:
Wavelength Range: 1525 nm to 1575 nm
Max. Output Power: 6dBm
Wavelength Accuracy (abs.): ±0.3nm
Wavelength repeatability (typ.): ±0.05pm
Signal to Source Spontaneous Emission Ratio: ³ 39dB/nm (full wavelength range)
Operates in the C-band
Option 021 = Stranded Single Mode Fiber & Straight Contact
Since this module is tunable and has continuous output power, it can be used to test optical amplifiers, DWDM components, and complete DWDM systems.
This card is compatible with the 8166A B Multichannel System, the 8164A B Lightwave Measurement System, and the 8163A B Multimeter.
主题回复
倒序浏览
1047查看1回复
2008-2-26 10:21:34
以下产品中国总代理:
美国EM4:
http://www.em4inc.com/
980nm 250mW-600mW泵浦激光器;
1550nm CW 40-80mW DFB激光器;
DC-18GHz高速PIN光电检测器;
808-980nm 3-7W高功率多模激光器;
1060nm 400mW 泵浦激光器;
1665nm 8mW DFB 激光器 (气体检测,蝶型封装)(美国INPHENIX公司);
英国Bookham:
http://www.bookham.com/
90μm 条宽808nm,915nm/940nm/980nm 3-8W 多模泵浦激光器 (管芯/C-Mount封);
高稳定度窄带光栅(±0.5nm)976nm 250mW 泵浦激光器(蓝光二次谐波及倍频);
1060nm/1070nm 400mW高功率单模激光器(BTF封装);
40-300W 808nm 高功率激光器Bar   (MCC/Cu Block 封装);
50-120W 915nm/940nm/980nm 高功率激光器Bar   (MCC/Cu Block 封装);
40W 1060nm/1070nm 高功率激光器Bar           (MCC/Cu Block 封装);
40W 915nm/940nm/980nm 单模高功率激光器Bar   (MCC/Cu Block 封装);
美国CIP:
http://www.ciphotonics.com/
1310nm/1550nm低偏振超辐二极管(SLED);
1550nm半导体光放大器(SOA);
1300nm/1550nm电吸收调制器(EAM);
40Gbit/s 2R光信号再生器(Optical Regenerators)。
芬兰Modulight:
http://www.modulight.com/
808nm 2W 多模泵浦激光器芯片;
808nm QCW 100W功率泵浦激光Bar;
1310nm 7mW DFB/FP激光器(芯片/TO-Can/同轴封装);
1490nm 6mW/10mW DFB激光器(芯片/TO-Can/同轴封装);
1550nm 5mW DFB/FP激光器(芯片/TO-Can/同轴封装);
NPN SILICON PLANAR AVALANCHE TRANSISTOR
NPN硅平面型雪崩三极管 - SMMT415、SMMT417
可用于:
激光二极管电源、驱动;
测试仪器;电子对抗;脉冲雷达;
UWB(Ultra Wideband) 脉冲无线电;
高速脉冲发生器;
SMMT415  、SMMT417
成都炬城微波科技有限公司
DFB/FP激光器,泵浦激光器,光纤耦合模块,激光二极管 光电探测器 光电子元器件 各种微波器件 MMIC MMDS下变频器
http://www.suncityinc.com.cn
Email:info@suncityinc.com.cn
TEL:028-85242020-803 李先生
举报 回复
