ANDO AQ8423Z 光放大器分析仪
854 0
发表于 2008-10-19 04:08:11|广东 | 查看全部 阅读模式
详细资料:
AQ8423Z Optical Amplifier Analyzer  Specifications
Measured wavelengths 1520 to 1620 nm
DUT input power range -45 to -6 dBm (min 0.1 dB step)
DUT output power range -30 to +30 dBm
Accuracy Gain measurement +/- 0.2 dB
NF measurement +/- 0.3 dB
DUT input power set +/- 0.2 dB
DUT output power measurement +/- 0.2 dB
Function Measurement Intensity dependency : input - NF, input - gain, output - NF, output - Gain, input - output
Stability : time - NF, time -gain, time - output
Display 1, 2 and 4 waveform display, numerical data display
Other Calendar and clock function, label function,
self calibration, self check
Self Calibration Optical output calibration,
optical fiber cable calibration,
system calibration
Storage Built in FDD 3.5 inch 2HD
Internal memory Waveform data and measurement parameter( for 16 waveform)
Data output Printer Built in High speed printer
Interface GP-IB standard
Other Video output(VGA compatible)
Display 9.4 inch color LCD (Resolution : 640 X 480 dots)
Optical I/O connector Main Unit FC type(advanced PC polished face)
DUT FC type(advanced PC polished face)
Power supply AC100 to 120V, 200 to 240V
48 to 63Hz, 200VA MAX
Environmental conditions Operating Temperature : 25 +/- 10 degrees centigrade
Storage Temperature : -10 to 50 degrees centigrade
Humidity : 80 % or less (non condensation)
Dimensions and mass Approx. 222(H) X 425(W) X 450(D) mm
Approx. 20kg
*1 : This specification is dependent on output power of light source
*2 : In precision measurement mode and calibration mode. At +/- 1 degree centigrade against certain room temperature.
黄先生
手机:13928415151
QQ:627906231
MSN :seanhuang82@hotmail.com
