2008-12-1 11:43:36 | 显示全部楼层 | 阅读模式
功率能量计
   Laser Point公司1987成立于意大利,是一家专业从事光电设备研发和生产的公司,在激光功率计和能量计等产品领域拥有几十年的研发经验,现已开发和生产的功率计能实现从微瓦级到万瓦级功率各种类型激光功率的测量
   Laser Point公司提供探头式功率能量计,主要有表面吸收热探头,准分子吸收体探头,体吸收热探头等。
表面吸收热探头
·产品性能特点:
·长时间功率测量
·激光准直
·激光稳定性测量
·长脉冲测量
·光源:He-Cd,Ar3+,Kr2+,Diode Lasers,Dye Lasers,CO2,Nd-YAG,Copper Vapors, IPL (Intense Pulsed Light)
Heads with Surface Absorbers.pdf
44.76 KB, 下载次数: 5, 下载积分: 光电贝 -1 元
Laser_Probes_Applications.pdf
150.82 KB, 下载次数: 4, 下载积分: 光电贝 -1 元
pg8_1_PlusSpecs.pdf
172.64 KB, 下载次数: 2, 下载积分: 光电贝 -1 元
主题回复
倒序浏览
2731查看5回复
2008-12-1 11:44:36
杨光,电话:13520381780
举报 回复
2008-12-3 23:59:59
我们正在找一下准的功率计请报价
HLASER@126.COM我们正在找一下准的功率计请报价
举报 回复
2009-2-23 14:01:27
Scientech Laser Power & Energy Measurement Systems
顶尖科仪(中国)公司
Scientech金牌服务
北京:13520381780
杭州:13552346276
Synenergy SystemsAstral Series Systems
[size=+1]Synenergy Systems[size=+1]Series Photodiode Systems
[size=+1]Series Calorimeter (thermal) Systems
Scientech, the industry leader in accurate laser power and energy measurement systems for over 38 years, is an American owned manufacturer where all our products are Made in the USA.
Model 301-LCCA Carrying CaseThe Model 301-LCCA carrying case is designed to embrace the S310 indicators along with Astral calorimeters, Vector pyroelectric detectors, and Ultra calorimeters as well as bases, cables, and power cords. BasesThese bases will hold the Astral , Ultra, and Vector detectors upright on your working surface. Base 11788, which is a slotted base, will bolt down to your optical bench. Base 301019 will work on any surface.
Model VH STANDThe VH STAND holds the H410 indicator upright on a table top. Model VH LCC Carrying CaseThe Model VH LCC carrying case handles the H410 indicators along with Astral calorimeters and Vector pyroelectric detectors as well as bases, cables, charger, and standard protective soft case.
Model 301-020R Photodiode DetectorThe high speed photodiode detector is designed for use with the 25 mm Astral calorimeters as an attachment to the calorimeter aperture. Energy scattered back from the calorimeter’s absorber when struck by an energetic pulse provides an attenuated sample of the incident laser pulse sufficient to activate the silicon diode. This provides a temporal profile of the laser pulse when viewed on an oscilloscope. An internal battery eliminates all wires except the coaxial cable to the sampling oscilloscope. Model 36-0203A Isoperibol™ EnclosureThe 36-0203A isolates the 25mm Astral calorimeters from environmental thermal disturbances which affect the stability of the calorimeter output when attempting low power and energy measurements. Scientech recommends using this enclosure when attempting power measurements below 30 mW and single pulse energy measurements below 30 mJ.
Fiberoptic Holder and AdaptersThe fiberoptic holder and adapters provide direct fiber hookup to the Astral calorimeter. Adapters that accept SMA, ST, FC, DIN, E2000 connectors or any 2.5 mm ferrule
Scientech+Synene.pdf
666.48 KB, 下载次数: 1, 下载积分: 光电贝 -1 元
举报 回复
2009-2-26 15:15:51
      功率能量计
表面吸收热探头
·产品性能特点:
1、可长时间功率测量
2、激光准直
3、激光稳定性测量
4、长脉冲测量
5、可测10000W工业激光
6、探测灵敏度可达10微瓦或2毫焦
7、高损伤阈值,功率密度6KW/CM平方,
·Laser Point公司1987成立于意大利,是一家专业从事光电设备研发和生产的公司,在激光功率计和能量计等产品领域拥有几十年的研发经验,现已开发和生产的功率计能实现从微瓦级到万瓦级功率各种类型激光功率的测量。
表面吸收热探头
测量范围和型号规格如下:
型号
功率范围
能量范围
光斑尺寸(mm)
波长范围(um)
A-X-DX-X
100mW~40W
0.5mJ~200J
12~60
0.19~25
A/W-X-DX-X
100mW~600W
1J~600J
25~60
0.25~11
W-X-DX-X
1W~6000W
n.a.
40~55
0.25~11
准分子吸收体探头——脉冲激光器
光源:Excimers @ 190nm, 258nm, 351nm, TEA CO2 Lasers, Copper Vapors
应用: 激光烧蚀,退火,平版印刷,皮肤医学,外科等。
准分子吸收体探头
测量范围和型号规格:
型号
功率范围
能量范围
光斑尺寸(mm)
波长范围 (um)
A-X-DX-X
100mW~40W
200mJ~600J
12~60
0.19~25
体吸收热探头——用于测量高峰值功率激光
光源:Nd-YAG, Nd-YFL, Diode and DPY, Erbium, Holmium, Flashlamps
应用:电阻调值 ,影印石版术,微加工,微电子学,激光清洁,外科整形等。
体吸收热探头
测量范围和型号规格:
型号
功率范围
能量范围
光斑尺寸(mm)
波长范围 (um)
A-X-DX-X
100mW~40W
25mJ~20J
12~60
0.19~25
LaserPoint公司提供三种不同类型的表头来显示测量结果,用户可根据各自要求选配。
PLUS
LPM
       PC-LINK
PLUS
LPM-OEM
LPM-CE
PC-LINK
可用探头类型
所有
所有
所有
显示方式
LCD
PLC
电脑
输出接口
RS-232或USB
RS-232
USB
波长是否选择
测量范围
0.1mW-10KW
1mJ-300J
0.1mW-10KW
1mJ-300J
0.1mW-10KW
1mJ-300J
举报 回复
2009-6-25 16:29:47
thanks to 大巴..................
举报 回复
