标题: 数控抛光非球面面形误差补偿技术研究 [打印本页]
作者: 风轻扬    时间: 2015-7-12 18:50
数控抛光非球面面形误差补偿技术研究
Research on Compensation of Computer Controlled Polishing  Aspheric Surface-Shape Error
下载全文
数控抛光非球面面形误差补偿技术研究.pdf (1.68 MB, 下载次数: 0)
作  者:徐海华
Xu Haihua( Department of Mechanical Engineering, Chongqing Three Gorges University,  Chongqing 404000, China)
机构地区:重庆三峡学院机械工程学院,重庆404000
出  处:《激光与光电子学进展》 CSCD 2014年第51卷第10期 172-176页,共5页
Laser & Optoelectronics Progress
摘  要:采用传统方法抛光高精度非球面时,多次面形误差补偿耗费时间占其抛光总时间的80%以上,严重影响非球面的加工效率。根据非球面的面形误差补偿原理,进行抛光非球面面形误差补偿的工艺实验。采用LOH—data—correct软件对非球面进行计算,并修正补偿其面形,可减少面形修正次数,降低成本,提高加工效率。
When the traditional method is used consumption of surface-shape error compensation for polishing high-precision aspheric surface, the time is more than 80% of the total polishing time. The efficiency of aspheric surface machining is severely affected. According to the principle of compensation for aspherical surface-shape error, process experiments of error compensation of polishing surface figure is conducted. By calculation and compensation of aspherical surface-shape using the software LOH-data-correct, the times of surface-shape correction and the cost are reduced, the machining efficiency is improved.
关键词:光学制造 抛光 非球面 面形误差 补偿技术
optical fabrication ; polishing ;aspheric surface ; surface-shape error ; compensation technology ;
