有报道luminus推出紫外LED UV cbt-120在309NM可达10W
4.8k 1
发表于 2010-5-3 22:39:50|广东 | 查看全部 阅读模式
Luminus Devices introduces UV PhlatLight LED
Luminus Devices, Inc., developer and manufacturer of big-chip PhlatLight? LEDs, today announced the UV CBT-120, the company’s first big-chip UV LED built on PhlatLight technology. The CBT-120 is ideally suited for a widely diverse number of industrial processes ranging from epoxy, ink, paint, laminate and adhesive curing to semiconductor processing.
LED tube Light
Dimmable led light
The UV CBT-120, based on Luminus’ award-winning large monolithic chip platform, is well-suited for UV applications that demand a high-flux of UV photons. The UV CBT-120 has a power density of 1 W/mm2, offering extremely high optical output of 10W at 390 nm.
“Traditionally, industrial curing applications have been forced to use high-wattage, high-intensity lamps due to the level of optical power density required for these applications,” said Alexei Erchak, CTO, Luminus Devices. “Now, with the release of the UV CBT-120, a solid-state lighting solution is available that can reach the requisite power levels and provide a new level of process control that is safe and reliable.”
The UV CBT-120 features high thermal-conductivity packaging, with a junction to heat sink thermal resistance of only 0.7 °C/W so it can reliably be driven to the demanding power levels necessary for industrial processing. It is an energy saving, environmentally friendly light souled light supplier
led light manufacturer
Wholesale LED Lamp rce lasting over 10,000 hours compared to 1,000 – 2,000 hours in traditional high intensity discharge lamps.
Samples are now available, full production is expected later in 2010. For inquiries on Luminus’ PhlatLight UV CBT-120 please visit: http://www.gosoled.com
wu4laohu Lv.8 发表于 2011-5-15 11:23:14|山东 | 查看全部
顶一下,不错不错....
