激光空间调制用的"高分辨率小尺寸的液晶板"
2.9k 2
发表于 2003-6-18 23:52:00|陕西 | 查看全部 阅读模式
本人为了做实验开发了激光空间调制用的高分辨率小尺寸的液晶板及其驱动电路.
那位人兄有兴趣可以交流一下应用!
yxiaojun@130-165.com
回复|共 2 个
zgzxb Lv.10 发表于 2003-6-19 01:50:00|湖北 | 查看全部
激光空间调制用的高分辨率小尺寸的液晶板
其工作原理,和应用范围是什么?
tft-lcd 楼主Lv.8 发表于 2003-6-19 07:35:00|陕西 | 查看全部
2.3cm (0.9 Type) Black-and-White LCD Panel
Description
The LCX029CNT is a 2.3cm diagonal active matrix
TFT-LCD panel addressed by polycrystalline silicon
super thin film transistors with a built-in peripheral
driving circuit. Use of three LCX029CNT panels
provides a full-color representation. The striped
arrangement suitable for data projectors is capable
of displaying fine text and vertical lines.
The adoption of DMS ∗1 structure and high light
resistance structure realize a high luminance screen.
And cross talk free circuit and ghost free circuit
contribute to high picture quality.
This panel has a polysilicon TFT high-speed scanner
and built-in function to display images up/down and/or
right/left inverse. The built-in 5V interface circuit leads
to lower voltage of timing and control signals.
The panel contains an active area variable circuit
which supports S-XGA 5:4 and PC-98 8:5 data signals
by changing the active area according to the type of
input signal.
∗1 Dual Metal Shield
Features
• Number of active dots: 786,432 (0.9 Type, 2.3cm in diagonal)
• XGA, SVGA, VGA, NTSC, PAL display
• SXGA display with simple display
• High optical transmittance: 16% (typ.)
• Built-in cross talk free circuit and ghost free circuit
• High contrast ratio with normally white mode: 400 (typ.)
• Built-in H and V drivers (built-in input level conversion circuit, 5V driving possible)
• Up/down and/or right/left inverse display function
• Antidust glass package
• Right twist liquid crystal
Element Structure
• Dots: 1024 (H) ×768 (V) = 786,432
• Built-in peripheral driver using polycrystalline silicon super thin film transistors
Applications
• Liquid crystal data projectors
• Liquid crystal multimedia projectors
• Liquid crystal rear-projector TVs, etc.
