悬赏问答
9回答 2940查看
悬赏 元光电贝
  提问于 2004-5-27 05:05:00
DWDM Network Designs and Engineering Solutions Author........: Ashwin Gumaste , Tony Antony , Tony Anthony Publisher.....: Cisco Press ISBN...............: 1587050749 Release Date..: 05-22-04 Publication Date...: December 13, 2002 FORMAT........: PDF Genre..............: IT Packager......: kB Supplier...........: kB
---------------------------------------------------------------- ---------------------------------------------------------------- A comprehensive book on DWDM network design and implementation solutions Design Software Included --Study various optical communication principles as well as communication methodologies in an optical fiber --Design and evaluate optical components in a DWDM network --Learn about the effects of noise in signal propagation, especially from OSNR and BER perspectives --Design optical amplifier-based links --Learn how to design optical links based on power budget --Design optical links based on OSNR --Design a real DWDM network with impairment due to OSNR, dispersion, and gain tilt --Classify and design DWDM networks based on size and performance --Understand and design nodal architectures for different classification of DWDM networks --Comprehend different protocols for transport of data over the DWDM layer --Learn how to test and measure different parameters in DWDM networks and optical systems The demand for Internet bandwidth grows as new applications, new technologies, and increased reliance on the Internet continue to rise. Dense wavelength division multiplexing (DWDM) is one technology that allows networks to gain significant amounts of bandwidth to handle this growing need. DWDM Network Designs and Engineering Solutions shows you how to take advantage of the new technology to satisfy your network's bandwidth needs. It begins by providing an understanding of DWDM technology and then goes on to teach the design, implementation, and maintenance of DWDM in a network. You will gain an understanding of how to analyze designs prior to installation to measure the impact that the technology will have on your bandwidth and network efficiency. This book bridges the gap between physical layer and network layer technologies and helps create solutions that build higher capacity and more resilient networks. Companion CD-ROM The companion CD-ROM contains a complimentary 30-day demo from VPIphotonicstrade; for VPItransmissionMakertrade;, the leading design and simulation tool for photonic components, subsystems, and DWDM transmission systems. VPItransmissionMaker contains 200 standard demos, including demos from Chapter 10, that show how to simulate and characterize devices, amplifiers, and systems.
http://www.amazon.com/exec/obidos/tg/detail/-/1587050749/
ftp://oecr.com/personal/badan's
主题回复
倒序浏览
2940查看9回复
2004-5-27 18:32:00
I can't open it , why?
举报 回复
2004-5-27 18:39:00
The file is ok!
举报 回复
2004-5-27 19:07:00
举报 回复
2004-5-27 23:55:00
回复:(badan)Ebook:Cisco.Press.DWDM.Network.Desi...
如何才连得上?
举报 回复
2004-5-28 17:51:00
USER:oecr
Pass:oecr
举报 回复
2004-5-29 00:25:00
很好的
good!!!!!
举报 回复
2004-5-29 06:38:00
use Cuteftp. Internet explorer cannot open it.
举报 回复
2004-5-31 23:49:00
下载了. 非常谢谢. 好东西.
举报 回复
2004-7-27 00:28:00
How can I get it.
举报 回复
