fiber optics introduction 1
2.3k 1
发表于 2004-7-13 04:10:00|南京大学鼓楼校区 | 查看全部 阅读模式
Introduction
Our current "age of technology" is the result of many brilliant inventions and discoveries, but it is our ability to transmit information, and the media we use to do it, that is perhaps most responsible for its evolution . Progressing from the copper wire of a century ago to today’s fiber optic cable, our increasing ability to transmit more information, more quickly and over longer distances has expanded the boundaries of our technological development in all areas.
Today’s low-loss glass fiber optic cable offers almost unlimited bandwidth and unique advantages over all previously developed transmission media. The basic point-to-point fiber optic transmission system consists of three basic elements: the optical transmitter, the fiber optic cable and the optical receiver. (See Figure 1.)
The Optical Transmitter: The transmitter converts an electrical analog or digital signal into a corresponding optical signal. The source of the optical signal can be either a light emitting diode, or a solid state laser diode. The most popular wavelengths of operation for optical transmitters are 850, 1300, or 1550 nanometers.
Most Fiberlink® transmission equipment manufactured by Communications Specialties operates at wavelengths of 850 or 1300nm.
The Fiber Optic Cable: The cable consists of one or more glass fibers, which act as waveguides for the optical signal. Fiber optic cable is similar to electrical cable in its construction, but provides special protection for the optical fiber within. For systems requiring transmission over distances of many kilometers, or where two or more fiber optic cables must be joined together, an optical splice is commonly used.
The Optical Receiver: The receiver converts the optical signal back into a replica of the original electrical signal. The detector of the optical signal is either a PIN-type photodiode or avalanche-type photodiode.
fifa Lv.8 发表于 2004-7-13 23:47:00|黑龙江 | 查看全部
哦
