公差分析請教
2.1k 3
发表于 2005-5-28 01:44:00|广东 | 查看全部 阅读模式
Title: Lens has no title.
Date : FRI MAY 27 2005
Units are Millimeters.
Paraxial Focus compensation is on. In this mode, all
compensators are ignored, except paraxial back focus change.
WARNING: RAY AIMING IS OFF. Very loose tolerances may not be computed accurately.
WARNING: Boundary constraints on compensators are ignored when
         using fast mode or user-defined merit functions.
Criteria            : Diffraction MTF average S&T at 120.0000 lp/mm
Mode                : Sensitivities
Sampling            : 1
Optimization Cycles : Automatic mode
Nominal Criteria    : 0.60319606
Test Wavelength     : 0.6328
Fields: User Defined Angle in degrees
#      X-Field      Y-Field       Weight    VDX    VDY    VCX    VCY
1   0.000E+000   0.000E+000   1.000E+000  0.000  0.000  0.000  0.000
2   0.000E+000   5.000E+000   1.000E+000  0.000  0.000  0.000  0.000
3   0.000E+000   1.200E+001   1.000E+000  0.000  0.000  0.000  0.000
4   0.000E+000   2.200E+001   1.000E+000  0.000  0.000  0.000  0.000
5   0.000E+000   2.500E+001   1.000E+000  0.000  0.000  0.000  0.000
6   0.000E+000   1.600E+001   1.000E+000  0.000  0.000  0.000  0.000
7   0.000E+000   2.700E+001   1.000E+000  0.000  0.000  0.000  0.000
Sensitivity Analysis:
                 |------------ Minimum ------------| |------------ Maximum ------------|
Type                   Value    Criteria      Change       Value    Criteria      Change
TFRN   2           -3.000000    0.479687   -0.123509    3.000000    0.441713   -0.161483
TFRN   3           -3.000000    0.601634   -0.001562    3.000000    0.602867   -0.000329
TFRN   4           -3.000000    0.594745   -0.008451    3.000000    0.592121   -0.011075
TFRN   5           -3.000000    0.603462    0.000266    3.000000    0.601679   -0.001517
TFRN   6           -3.000000    0.578954   -0.024242    3.000000    0.579403   -0.023793
TFRN   7           -3.000000    0.602964   -0.000232    3.000000    0.602841   -0.000355
TFRN   8           -3.000000    0.602989   -0.000207    3.000000    0.603361    0.000165
TTHI   1   4       -0.020000    0.570874   -0.032322    0.020000    0.581045   -0.022151
TTHI   2   4       -0.020000    0.549013   -0.054183    0.020000    0.550614   -0.052582
TTHI   3   4       -0.020000    0.525284   -0.077912    0.020000    0.520713   -0.082483
TTHI   4   6       -0.020000    0.588266   -0.014930    0.020000    0.583481   -0.019715
TTHI   5   6       -0.020000    0.446348   -0.156848    0.020000    0.487089   -0.116107
TTHI   6   8       -0.020000    0.579337   -0.023859    0.020000    0.575690   -0.027506
TTHI   7   8       -0.020000    0.594398   -0.008798    0.020000    0.595983   -0.007213
TSDX   2           -0.020000    0.420259   -0.182937    0.020000    0.420259   -0.182937
TSDY   2           -0.020000    0.281774   -0.321422    0.020000    0.310363   -0.292834
TSTX   2           -0.020000    0.596023   -0.007173    0.020000    0.597218   -0.005978
TSTY   2           -0.020000    0.601943   -0.001253    0.020000    0.601943   -0.001253
TSDX   3           -0.020000    0.589117   -0.014080    0.020000    0.589117   -0.014080
TSDY   3           -0.020000    0.582197   -0.020999    0.020000    0.581598   -0.021598
TSTX   3           -0.020000    0.603186   -0.000010    0.020000    0.603090   -0.000106
TSTY   3           -0.020000    0.603159   -0.000037    0.020000    0.603159   -0.000037
TSDX   4           -0.020000    0.571869   -0.031327    0.020000    0.571869   -0.031327
TSDY   4           -0.020000    0.586362   -0.016834    0.020000    0.571178   -0.032018
TSTX   4           -0.020000    0.602017   -0.001179    0.020000    0.603719    0.000523
TSTY   4           -0.020000    0.602785   -0.000411    0.020000    0.602785   -0.000411
TEDX   5   5       -0.020000    0.448350   -0.154847    0.020000    0.448350   -0.154847
TEDY   5   5       -0.020000    0.457446   -0.145750    0.020000    0.506980   -0.096216
TETY   5   5       -0.020000    0.602605   -0.000591    0.020000    0.602605   -0.000591
TETX   5   5       -0.020000    0.601424   -0.001772    0.020000    0.602482   -0.000714
TEDX   6   6       -0.020000    0.306607   -0.296589    0.020000    0.306607   -0.296589
TEDY   6   6       -0.020000    0.289152   -0.314044    0.020000    0.238001   -0.365195
TETY   6   6       -0.020000    0.602821   -0.000376    0.020000    0.602821   -0.000376
TETX   6   6       -0.020000    0.603966    0.000770    0.020000    0.601704   -0.001492
TEDX   7   7       -0.020000    0.598631   -0.004565    0.020000    0.598631   -0.004565
TEDY   7   7       -0.020000    0.587099   -0.016097    0.020000    0.589824   -0.013372
TETY   7   7       -0.020000    0.603134   -0.000062    0.020000    0.603134   -0.000062
TETX   7   7       -0.020000    0.603667    0.000471    0.020000    0.602603   -0.000593
TEDX   8   8       -0.020000    0.597022   -0.006174    0.020000    0.597022   -0.006174
TEDY   8   8       -0.020000    0.580444   -0.022752    0.020000    0.582103   -0.021093
TETY   8   8       -0.020000    0.603168   -0.000028    0.020000    0.603168   -0.000028
TETX   8   8       -0.020000    0.602787   -0.000409    0.020000    0.603555    0.000359
Worst offenders:
TEDY   6   6        0.020000    0.238001   -0.365195
TEDX   6   6        0.020000    0.306607   -0.296589
TSDY   2            0.020000    0.310363   -0.292834
TSDX   2            0.020000    0.420259   -0.182937
TFRN   2            3.000000    0.441713   -0.161483
Estimated Performance Changes based upon Root-Sum-Square method:
Nominal MTF              :     0.6032
Estimated change         :    -0.6525
Estimated MTF            :     0.0000
Compensator Statistics:
Change in back focus:
Minimum            :        -0.037864
Maximum            :         0.038187
Mean               :         0.000006
Standard Deviation :         0.007701
Monte Carlo Analysis:
Number of trials: 20
Initial Statistics: Normal Distribution
  Trial    Criteria      Change
      1    0.462476   -0.140720
      2    0.293929   -0.309267
      3    0.237763   -0.365433
      4    0.279259   -0.323937
      5    0.498807   -0.104389
      6    0.169956   -0.433240
      7    0.438412   -0.164784
      8    0.354122   -0.249074
      9    0.499252   -0.103944
     10    0.335771   -0.267426
     11    0.354722   -0.248474
     12    0.419868   -0.183328
     13    0.294237   -0.308959
     14    0.231824   -0.371372
     15    0.228376   -0.374820
     16    0.281652   -0.321544
     17    0.348539   -0.254657
     18    0.359151   -0.244045
     19    0.415642   -0.187554
     20    0.244824   -0.358372
Nominal    0.603196
Best       0.499252
Worst      0.169956
Mean       0.337429
Std Dev    0.092738
Minimum            :        -0.045345
Maximum            :         0.033900
Mean               :        -0.000576
Standard Deviation :         0.016412
90% >=     0.228376
50% >=     0.335771
10% >=     0.462476
End of Run.
請教各位高手指點
回复|共 3 个
zhouqihui 楼主Lv.8 发表于 2005-5-30 21:54:00|广东 | 查看全部
請教可行性評估
通過以上公差分析,可行性如何,對加工難易要求如何?
hemet Lv.8 发表于 2005-5-28 17:14:00|浙江 | 查看全部
这是ZEMAX的报告,你应该指明哪里不清楚,哪里有问题呀!
hemet Lv.8 发表于 2005-5-31 17:02:00|浙江 | 查看全部
推荐看一下论坛GGX19458132写的光学镜头的公差分配(1)和(2),不同系统对公差有不同要求的。
