2005-8-3 22:44:00 | 显示全部楼层 | 阅读模式
Deqing HuaRui-optics Components Co., Ltd
HR-OPTICS devotes itself to development of all kinds new optical single crystals, optic wafers and optic passive components. For passing 10 years over we enjoyed our abundance experience at growing and mass production of optical grade Lithium Niobate / Lithium Tanatalate single crystal and it's wafers. We are equipped with advanced facilities at crystal growing, wafer lapping and polishing, all finished products are passed at Testing and QC inspection.
Our R D is active at developing and researching from new materials to finished products at all kinds of optical electronic components.
Our products ranges
1) Materials :
a. Optical Lithium Niobate ( X,Y,Z orientations etc . diameter 3" ) crystal and it's wafers .
b: FeN, Mg N, crystal and it's wafer
c: Lithium Niobate for Saw filter usage crystal and it's wafers
d: Lithium tanatalate (LiTao3) crystal and it's wafers ( 36deg , Z directions . size diameter as 3" );
2) component :
a . LN optical modulation,(4*2.5*60mm)
Q-Switch(9*9*25,6*6*25,16*16*35mm)
b: LN optical waveguide substrate ( for integrated optical waveguide elements )
c: wave plates ( Quartz) :
d: LN wedge with many directions for isolater usage(12° 13°、15°)
LiNbO3 Wedges/Birefringent Substrates for use in fiber optics
Specifications:
Aperture
1.0 x 1.0 mm2 to 4 x 4 mm2
Dimension tolerance
+/-0.05mm
Wedge Angle tolerance
+/-0.1o
Optical axis orientation
+/-0.5o
Flatness
l/4 @632.8 nm
Surface Quality
20-10
AR-coating
R0.2%
Standard Sizes
a) 1.25mmx1.25mmx0.25mm(top end) or
0.55mm(bottom end)
b) 1.6mmx1.6mmx0.55mm
Cutting Angle
q=90o, f=22.5o
Wedge Angle
13o or 15o
Coating
Two apertures AR coated typically for ~1550nm
Quantities Available
50,000 to 70,000 per month
Note: Other sizes and coatings are available upon request.
LiNbO3 Q-Switch Elements
Standard Dimension
9x9x25 or 10x10x20mm3 (other dimension is also available upon request)
Dimension Tolerance
X Y-axis: ± 0.1mm ; Z-axis: ± 0.3mm
Wavefront Distortion
l/4 @633nm
Orientation Accuracy
X Y-axis: 10'; Z-axis: 5'
Flatness
l/8 @632.8nm
Parallelism
10"
Scratch/Dig Code
10/5 per MIL-O-13830A
Chamfer
0.5 mm at 45º ± 5º
AR-Coating
R 0.2% @ 1064 nm
Electrodes
Gold or Cr electrode on X-faces
Extinction Ratio
400:1 @ 633 nm for f 6mm beam)
Bsic Specifications of LiNbO3 SAW Wafer
Standard Dimension
f3.0² (±0.01²) x 0.51 mm (±0.05 mm)
Typical Orientation
1) 127.86° Y-cut, 2) 64° Y-cut, 3) Y-cut, 4) Z-cut
Surfaces Finish
One surface mirror polished to Ra less than 10Å, reverse surface fine ground
Bow
20 mm
Typical properties of LiNbO3 SAW Wafer
Orientation
127.86° Y-cut
Y-cut
SAW Velocity
3970 m/s
3485 m/s
Electromechanical Coupling Factor
Ks2=5.5%
Ks2=4.3%
Temperature Coeff. of Delay (TCD)
78 x 10-6/°C
95 x 10-6/°C
Temperature Coeff. of Velocity (TCV)
-60 x 10-6/°C
-80 x 10-6/°C
Waveguide Substrates
LiNbO3 crystal is the mostly used inorganic substrate for electro-optic waveguide applications.
Specifications of LiNbO3 Waveguide Substrates
Standard Dimension
1) 50x50x1 mm3 for X-cut, Y-cut, or Z-cut
2) f 3"x1 m m3 for Y-cut or Z-cut
3) Other dimension is available upon request.
Orientation Tolerance
10'
Surfaces Finish
One surface polished to better than l/2 (with mount) and free from surface defects when observed by a 50X microscope, the other face fine ground
PLANT:
No.333 Changhong street(M), Wukang Town,
Deqing County, Zhejiang P.R.China
ZIP313200
TEL:0086-572-8083398
FAX:0086-572-8083397
Cell: 0086-013967269976
0086-013362288444
E-mail:lczoptics@yahoo.com.cn
[此贴子已经被作者于2005-8-3 14:48:30编辑过]
主题回复
倒序浏览
1473查看6回复
2005-8-3 22:53:00
玻璃柱面镜(棒镜)
规格:直径1~30mm,长度1~200mm
举报 回复
2005-8-3 23:12:00
公司主要生产以下产品
单晶材料类:
a. 光学铌酸锂(X、Y、Z等方向生长,最大尺寸3")单晶及晶片。
b. 掺杂铌酸锂(掺铁、掺镁、双掺杂等,最大尺寸3")单晶及晶片;
c. 声学级铌酸锂(各种生长方向,最大尺寸4")单晶及晶片
d. 钽酸锂LiTaO3单晶及晶片。
e. 石英晶片。
玻璃材料类:
a、 高精度平面,最大直径300mm
b、 柱面镜,最大直径50mm,最长尺寸200mm.
成型器件:
a. 光调制器(铌酸锂)规格;4*2 .5*60mm
b. 调Q开关(铌酸锂),规格:9*9*25,6*6*25,16*16*35 mm
c. 光波导(铌酸锂)基片;
d. 各种角度铌酸锂楔形片(LiNbO3 Wedge)等。
e. 激光模组用一字镜、十字镜(Φ2-50mm*5—150mm )
f. 3"LN晶片。
举报 回复
2005-8-4 00:19:00
举报 回复
2005-8-4 22:41:00
举报 回复
2005-8-6 17:30:00
最新产品:超长玻璃圆柱棒
技术特点:1、直径3mm,4mm,5mm,6mm 等各种规格.
2、端面、柱面抛光,S/D;60/40
3、椭圆度〈0.005mm
4、长度,直径3mm为150mm,直径4mm以上为200mm.
举报 回复
2005-8-8 22:36:00
公司外协各种玻璃\晶体抛光棒.
需求请联系! lczoptics@yahoo.com.cn
举报 回复
