2005-11-14 21:54:00 | 显示全部楼层 | 阅读模式
LiNbO3
On its excellent optical and electrical properties, LiNbO3 is one of the most important materials used for the field of optics and electronics, such as laser components, wafers for surface acoustic wave devices, wafers for integrated optics applications and doped LiNbO3 crystals for nonlinear optics (MgOiNbO3, ZnO: LiNbO3), photo-refractive effects devices (FeiNbO3), etc.
OPO, Frequency and Quasi-Phase-Matched (QPM) Doublers
LiNbO3 is commonly applied as not only frequency doubler (wavelength 1 mm) but optical parameter oscillator (OPO) pumped at 1.064 mm, as well quasi-phase-matched (QPM) doubler. HROPTICS supplies laser-grade LiNbO3 devices of (3-20) x (3-20) mm2 aperture and up to 60 mm length for frequency doubler and optical parameter oscillator, with high quality, large quantity and low price. Its properties show as follows:
Basic Properties
Crystal Structure
Trigonal, point group 3m
Lattice Parameters
a=5.148Å, c=13.863Å
Density
4.64 g/cm3
Melting Point
1250 °C
Curie Point
1160 °C
Mohs Hardness
Dielectric Constant
e11/e0 = 85; e33/e0 = 29.5
Absorption Coefficient
~ 0.1%/cm @1064 nm
Thermal Conductivity
38 W/m/°C at 25°C
Thermal Expansion Coefficient
a1=a2 =2x10-6/°C, a3=2.2x10-6/ °C at 25°C
Piezoelectric Strain Constant
d22 = 2.04 x 10-11 C/N, d33 = 19.22 x 10-11 C/N
Elastic Stiffness Constant
CE11 = 2.04 x 1011 N/m2, CE33 = 2.46 x 1011 N/m2
Optical and NLO Properties
Transparency Region
3700 ~ 5000 nm
Sellmeier Equations (l in mm)
no2 = 4.9048+0.11768/(l2-0.0475)-0.027169l2
ne2 = 4.5820+0.099169/(l2-0.04443)-0.02195l2
Optical Homogeneity
Dn ~ 5x105/cm2
Nonlinear Coefficients
deff=13.6 d36(KDP) for OPO at 1064 nm
deff =14.6 d36(KDP) for SHG at 1300 nm
deff =45.0 d36(KDP) for QPM
Refractive Indexes
no ne
2.220 2.146 @ 1300 nm
2.322 2.156 @ 1064 nm
2.286 2.203 @ 632.8 nm
Electro-optic Coefficients (pm/V)
Low frequency High frequency
g33 32 31
g31 10 8.6
g22 6.8 3.4
Damage Threshold
250 KW/cm2 at 1064 nm (10 ns)
X-CUT
76.2 diameter*0.5---1.0mm HR-LNX0305-10
Z-CUT
76.2 diameter*0.5---1.0mm HR-LNZ0305-10
Y-CUT
76.2 diameter*0.5---1.0mm HR-LNY0305-10
127.86° Y-cut,
76.2 diameter*0.50mm HR-LNY1040305
64° Y-cut,
76.2 diameter*0.5mm HR-LNY640305
Applications for Q-switch Elements
LiNbO3 is extensively used as electro-optic modulator and Q-switch for Nd:YAG, Nd:YLF and Ti:Sapphire lasers as well as modulator for fiber optics, etc. The transverse modulation is mostly employed for LiNbO3. If a LiNbO3 crystal is used as Q-switch crystal, the light propagates in Z-axis and electric field applies to X-axis, the refractive retardation will be G = pLno3¡22V/ld. MgOiNbO3 and ZnO: LiNbO3 crystals have similar electro-optic properties to LiNbO3 but with higher damage threshold. The specifications of LiNbO3 Q-Switch Elements listed as the following table:
Standard Dimension
9x9x25 or 10x10x20mm3 (other dimension is also available upon request)
Dimension Tolerance
X Y-axis: ± 0.1mm ; Z-axis: ± 0.3mm
Wavefront Distortion
l/4 @633nm
Orientation Accuracy
X Y-axis: 10'; Z-axis: 5'
Flatness
l/8 @632.8nm
Parallelism
10"
Scratch/Dig Code
10/5 per MIL-O-13830A
Chamfer
0.5 mm at 45º ± 5º
AR-Coating
R 0.2% @ 1064 nm
Electrodes
Gold electrode on X-faces
Extinction Ratio
400:1 @ 633 nm for f 6mm beam)
Surface Acoustic Wave (SAW) Devices
LiNbO3 crystal is widely applied as an excellent acousto-optic material for surface acoustic wave (SAW) devices (such as filters, oscillators and resonators) and ultrasonic transducer due to its high electro-mechanical coupling factor, low acoustic transmission loss, stable physical and chemical properties.
HROPTICS can supply large quantities of LiNbO3 boules, as-cut or finished f3" wafers available up to 6,000~ 9,000 pieces per month with good quality and very low price. The basic specifications and typical properties for LiNbO3 SAW wafer are listed as following:
Bsic Specifications of LiNbO3 SAW Wafer
Standard Dimension
f3.0² (±0.01²) x 0.51 mm (±0.05 mm)
Typical Orientation
1) 127.86° Y-cut, 2) 64° Y-cut, 3) Y-cut, 4) Z-cut
Surfaces Finish
One surface mirror polished to Ra less than 10Å, reverse surface fine ground
Bow
20 mm
Typical properties of LiNbO3 SAW Wafer
Orientation
127.86° Y-cut
Y-cut
SAW Velocity
3970 m/s
3485 m/s
Electromechanical Coupling Factor
Ks2=5.5%
Ks2=4.3%
Temperature Coeff. of Delay (TCD)
78 x 10-6/°C
95 x 10-6/°C
Temperature Coeff. of Velocity (TCV)
-60 x 10-6/°C
-80 x 10-6/°C
LiNbO3 Wedges/Birefringent Substrates for use in fiber optics
Specifications:
Aperture
1.0 x 1.0 mm2 to 4 x 4 mm2
Dimension tolerance
+/-0.05mm
Wedge Angle tolerance
+/-0.1o
Optical axis orientation
+/-0.5o
Flatness
l/4 @632.8 nm
Surface Quality
20-10
AR-coating
R0.2%
Standard Sizes
a) 1.25mmx1.25mmx0.25mm(top end) or
0.55mm(bottom end)
b) 1.6mmx1.6mmx0.55mm
Cutting Angle
q=90o, f=22.5o
Wedge Angle
13o or 15o
Coating
Two apertures AR coated typically for ~1550nm
Quantities Available
50,000 to 70,000 per month
Waveguide Substrates
LiNbO3 crystal is the mostly used inorganic substrate for electro-optic waveguide applications.
Specifications of LiNbO3 Waveguide Substrates
Standard Dimension
1) 50x50x1 mm3 for X-cut, Y-cut, or Z-cut
2) f 3"x1 m m3 for Y-cut or Z-cut
3) Other dimension is available upon request.
Orientation Tolerance
10'
Surfaces Finish
One surface polished to better than l/2 (with mount) and free from surface defects when observed by a 50X microscope, the other face fine ground
. Magnesium Oxide Doped Lithium Niobate (MgOiNbO3)
MgOiNbO3 crystal is widely used for high power frequency doubling(SHG), mixing(SFG) and optical parameter oscillator(OPO). MgOiNbO3 has similar effective nonlinear coefficients as pure LiNbO3. But it has the advantages such as high damage threshold (over 5 GW/cm2 @ 1064 nm, 12ns), noncritical phase matching (NCPM) at room temperature, excellent E-O and NLO properties, good mechanical and chemical properties compared with pure LiNbO3.
Its Sellmeier equations (7 mol% MgO doping) are:
no2 = 4.8762+0.115540/(l2-0.04674)-0.033119l2 (l in mm)
ne2 = 4.5469+0.094779/(l2-0.04439)-0.026721l2
Over 45% and 60% of SHG efficient are obtained in pulsed and cw Nd:YAG lasers respectively, by angle tuned phase matchable SHG of Nd:YAG laser (1064 nm) and NCPM SHG of laser lasers (1053 nm) of MgOiNbO3 at room temperature. MgOiNbO3 is also a good crystal for high power quasi-phase-matched waveguide structure for doubler, optical parametric oscillator (OPO) and amplifier (OPA).
HROPTICS supplies the typical sizes of MgOiNbO3 crystals - 5x5x(20-30) mm3 for OPO and frequency doubler, (20-25)x(20-25)x1 mm3 for waveguide substrates. Other sizes and AR or HR-coatings are available upon request.
. Iron Doped Lithium Niobate (FeiNbO3)
FeiNbO3 is a excellent photorefractive crystal with high electro-optic coefficients, high photorefractive sensitivity and diffraction efficiency without applied electric field. Therefore, FeiNbO3 crystal will find the suitable applications in phase conjugation and holographic recording. High quality FeiNbO3 crystal, with size as large as f3" and iron doped concentrations from 0.01 to 0.1 atm%, could be supplied by HROPTICS Some special fabrications are also available to meet customers'
主题回复
倒序浏览
1215查看3回复
2005-11-14 21:59:00
我们的企业文化:
我们的目标:做中国最好的光学元件公司
我们的使命:客户满意
我们的理念:以人为本、德才兼备,品德为先
我们的价值观:为客户创造价值,公司与客户共同发展
我们的文化:学习、创新、人本
质量方针:不断完善质量体系,不隐瞒\不欺骗.树立华瑞品牌.
[此贴子已经被作者于2005-11-14 14:02:19编辑过]
举报 回复
2005-11-14 22:01:00
激光模组用玻璃一字镜
 一字镜(棒镜)
K玻璃材料
规格:Φ1*8mm Φ2*5mm Φmm*6mm Φ 2.5*4mm Φ 2.9*7.7mm Φ3*5mm Φ3*6mm Φ3*7mm Φ 4*5mm Φ 4*6mm Φ4*7mm Φ4.5*7mm Φ5*5mm Φ5*6mm Φ 5*7mm Φ5*8mm Φ6*8mm Φ6*9mm Φ9*22mm Φ10*22mm Φ10*60mm Φ10*85mm Φ32*22mm Φ2.3*110mm Φ3*150mm Φ4*200mm Φ5*200mm
F玻璃材料
S玻璃材料
地线仪用柱面镜
规格:9*9*4.5mm8*8*4mm
激光模组用六棱镜
规格:4.5*5.5*9mm
激光模组用透镜
规格:Φ5*3Φ8*3(单件、胶合件)
激光模组用窗口片
规格:Φ6*1mm Φ8*1mm Φ10*1mm AR0.02%@635-670nm
举报 回复
2005-11-14 22:21:00
德清华瑞光学元件有限责任公司
Deqing Huarui optics Components Co., Ltd.
李春忠 总经理
地址:浙江省德清县武康镇长虹中街333号
ADD: No.333 Changhong street(M), Wukang Town,
Deqing County, Zhejiang P.R.China
电话(TEL):0572-8083398 8082876传真(FAX):0572-8083397
手机(Mobile):13362288444 13967269976
E-mail: lczoptics@yahoo.com.cn lczoptics@hotmail.com
http://www.hroptics.com
举报 回复
