mems siwtch ; mems VOA 提供所有类型的开关
1.4k 0
发表于 2007-1-8 23:29:00|广东 | 查看全部 阅读模式
MEMs Optical 1x2 Switch
The C-OPTIC’s 1x2;2X2 switch is a very fast opto-mechanical switch based on the latest silicon MEMS technology and uses micro-mechanical mirrors to redirect the light. The switch is built by cascading 1x2;2X2 switches which are qualified according to Telcordia GR1073
Features Applications
High reliability Optical Reconfiguration
Low insertion loss Instrumentation
TTL or CMOS drive WDM
Latching or non-latching
Specifications
Parameter
Value
Unit
Wavelength range
1250~1640,600~1700(multi-mode)
nm
Insertion loss
typ.0.8,max 1.2
dB
Return loss
=45
dB
Polarization dependent loss
0.1
dB
Cross talk
Typ.60, Max 55
dB
Repeatability
=0.01
dB
Switch speed
20, max 30
ns
Operating Voltage
VDC
Power Consumption
typ 10, max 50
mW
Operation temperature
0~65
Storage temperature
-40~80
Durability
1billion
degree
Size
¢5.5 x 35
mm
Ordering Information
Mode
Switch hannel
Latching or Non-Latching
Fiber Type
Fiber Length
Connector
SM
MM
14=1x4
18=1x8
110=1x10
112=1x12
113=1x13
116=1x16
3232=32X3
L=Latching
N=Non-Latching
S9=SMF
9/125/900um
M5=MMF 50/125/900um
M6=MMF 62.5/125/900um
XX=others
1=1.0m
2=2.0m
XX=others
NE=None
FA=FC/APC
FC=FC/PC
SA=SC/APC
SC=SC/PC
ST=ST/PC
LA=LC/APC
LC=LC/PC
XX=others
先放个有代表性的开光参数!CHIP 自主研发,对于价格方面我们具有很好的价格优势!
