昊量光电专业代理英国Stratophase公司 周期性极化铌酸锂(PPLN)
1.4k 2
发表于 2009-2-13 21:52:54|上海 | 查看全部 阅读模式
  成立于2003年的Stratophase公司源于英国南安普顿大学的科研项目。由多加风险投资公司共同组建的Stratophase公司拥有多名技术专家与市场专业人员,在专业领域具有丰富的经验。其产品包括:生化探测器、红外激光系统、周期性极化铌酸锂(PPLN)及附件。
回复|共 2 个
haoliang123 楼主Lv.6 发表于 2009-2-14 20:21:03|上海 | 查看全部
产品名称:PPLN for OPO/OPG
所属类别:
周期性极化铌酸锂(PPLN)
厂家名称:英国Stratophase公司
产品简介: Stratophase’s range of OPO crystals are designed to be pumped using a wide variety of laser sources with wavelengths in the region of 1064nm. These crystals can also be used for other applications such as optical parametric generation and optical parametric amplification.
AR Coated: Input and Output facets approximately <1%R @ specified Pump, Signal and Idler wavelengths
Multiple Gratings allow continuous tuning of signal/idler via temperature and period selection
High Efficiency generation of wavelengths between 1.3 to 5.0&micro;m.
These crystals are available in other lengths and with different coatings as semi-standard products
Crystals for other wavelengths are available as semi-standard or custom products.
Item No
Pump (um)
Signal (um)
Idler
(um
Poled Periods (um)
Temperature Range (0C)
Crystal Length (mm)
Grating Aperture (mm)
OPO1-20
1.064
1.35-
1.41
5.1-
4.34
25.00, 25.25, 25.50, 25.75, 26.00,
26.25,26.50,26.75,27.00
100-200
20
0.5x0.5
OPO1-40
40
OPO2-20
1.064
1.41-
1.58
4.36-
3.46
27.25, 27.50, 27.75, 28.00, 28.25,
28.50, 28.75, 29.00, 29.25
100-200
20
0.5x0.5
OPO2-40
40
OPO3-20
1.064
1.52-
2.13
3.54-
2.13
29.50, 29.75, 30.00, 30.25, 30.50,
30.75, 31.00, 31.25, 31.50
100-200
20
0.5x0.5
OPO3-40
40
OPO4-20
1.064
1.45-
1.49
4.01-
3.72
28.60, 28.39, 28.52, 28.65
100-200
20
1.0x1.0
OPO4-40
40
OPO5-20
1.064
1.52-
1.59
3.55-
3.20
29.44, 29.55, 29.66, 29.78
100-200
20
1.0x1.0
OPO5-40
40
OPO6-20
1.064
1.60-
1.80
3.18-
2.60
30.26, 30.39, 30.52, 30.67
100-200
20
1.0x1.0
OPO6-40
40
haoliang123 楼主Lv.6 发表于 2009-2-16 21:30:12|上海 | 查看全部
产品名称:PPLN for Second Harmonic Generation
所属类别:
周期性极化铌酸锂(PPLN)
产品简介: Stratophase’s range of Standard SHG crystals are designed to frequency double a wide range of common laser wavelengths. Each crystal type is available in two lengths; 1mm for short pulsed pump sources and 10mm for longer pulses or CW pump sources.
AR Coated; Input facet approximately <0.5%R @ Fundamental wavelength, Output facet approximately <0.5%R @ Second Harmonic wavelengths
Multiple Grating; continuous tuning of Fundamental/Second Harmonic wavelengths via temperature/grating selection.
High efficiency frequency doubling of wavelengths in the range 980nm to 2200nm
Crystals for frequency doubling other wavelengths are available as semi-standard or custom products.
Item No
Fundamental (nm)
Second Harmonic
(nm)
Poled Periods (um)
Crystal Length
(mm)
Grating Aperture
(mm)
SHG8-1
976.7-984.7
488.4-492.4
5.00, 5.04, 5.08
160-200
0.5x0.5
SHG3-1
1.059.8-1067.6
529.9-533.8
6.50, 6.54, 6.58
160-200
0.5x0.5
SHG3-10
10
SHG4-1
1308.9-1321.8
654.5-660.9
12.10, 12.20, 12.30
160-200
20
0.5x0.5
SHG4-10
40
SHG5-1
1540.0-1576.7
770.0-788.4
18.20, 18.40, 18.60, 18.80, 19.00
160-200
20
0.5x0.5
SHG5-10
40
SHG6-1
1569.8-1652.8
784.9-826.4
19.00, 19.25, 19.50, 19.75, 20.00, 20.25, 20.50, 20.75, 21.00
160-200
20
0.5x0.5
SHG6-10
40
SHG7-1
2024.3-2250.6
1012.3-1125.3
29.50, 30,00, 30.50, 31.00,
31.50, 32.00, 32.50
160-200
20
0.5x0.5
SHG7-10
40
