2010-3-9 17:59:57 | 显示全部楼层 | 阅读模式
产品名称:双光子,多光子显微专用激光功率控制系统。
所属类别:
多光子显微专用激光功率控制系统
厂家名称:美国ConOptics公司
产品简介:
Conoptics公司是双光子显微/多光子显微专用激光功率控制系统的先行者。Conoptics专门为飞秒钛宝石激光器的功率控制设计了一套相应的系统,这套系统也成为了多光子显微领域通用的解决方案。
Aperture 3.5mm
Dimensions 50mm Diameter x 135mm
Transmission >90%
Standard Wavelength Ranges 700 – to – 1100nm
Piezo Resonances Minimal with clamped version (BK option)
Driver Compatibility Full modulation with M302 Power Amplifier up to 1064nm
  Amplifier Key Features:
Cabinet Driver and power supply in single cabinet
Test Feature Built-in test feature allows testing for max transmission of Pockel Cell without adjusting bias voltage
Input Impedance Choice of amplifier input impedance by rear panel switch (50ohm/1K ohm)
DC Bias Improved DC biasing of Pockel Cell provides greater linearity at higher bias voltages
Voltage Range +/- 450VDC controlled by ten-turn front panel pot. Digital meter monitors differential bias applied to E.O. Modulator
Linearity 10bits referenced to full scale (.1%)
Bandwidth DC to >200Khz with 90pf load and 3M (RG-62) cables
Max. Output Drive Level 750VP-P into 90pf load
Amplifier Input Signal 2VP-P max into 50/1K ohms delivers 750VP-P out
Input Signal Format Options include Unipolar positive, negative or bipolar
Input Power (AC) 60W typical. Input power is both load (modulator) and frequency dependent.
Dimensions 19” Rack Mountable, 5.25”H(133mm) (3U) x 14”D (356mm)
Cooling Forced air
Operating Environment Designed for laboratory use (indoor only) Temperature range +5deg C to +50deg C ambient Humidity 20%-80% RH up to 32deg C Altitude <3000M
Weight 20lbs (9.07kg)
如需任何进一步信息,请和昊量光电联系!
