由asp编写的一个完整聊天室原代码
2.3k 0
发表于 2003-4-5 17:41:00|辽宁 | 查看全部 阅读模式
2003-1-9 ·来源:www.gaofeng.org
完整的聊天室原代码(login_chat.htm ,default.htm ,global.asa, chat.asp)
login_chat.htm
html
head
title登记进入聊天室/title
script language=vbscript
function ao()
li.name.value=Trim(li.name.value)
if li.name.value= then li.name.value=匿名来客
li.submit
end function
function ch(whichobj)
whichobj.checked=true
end function
/script
/head
body background=backchat.jpg bgcolor=#FFFFFF
table height=100%
tr
td valign=center
center
font color=#FF0000 size=5 face=隶书聊 天 室/font
form name=’li’ action=uif.asp method=POST align=center
请输入您的姓名:
input type=text size=18 name=name style=font-size: 12pt
input type=button name=B1 onClick=’ao()’ value=进入 style=
font-size: 12pt
/form
font color=#0000ff size=5 face=隶书注意事项/font/center
ol
lifont size=3请将本窗口strong最大化/strong,这样可得到最
佳的视觉效果。/font/li
lifont size=3在聊天过程中,请注意strong语言使用/strong,
strong尊重对方/strong。请不要使用不适合学生使用的语言。/font/li
/ol
/td/tr
trtd valign=buttom align=center
a href=mailto:whitek@netease.com本聊天室有 小宝 制作,欢迎您提出宝贵
建议/a
/td/tr
/table
/body
/html
default.htm
html
head
title聊天室/title
/head
frameset cols=*,150
frameset rows=*,0
frame name=uif src=login_chat.htm noresize
frame name=sendwords border=0 src=about:blank noresize
/frameset
frame name=refresh src=userlist.asp noresize
/frameset
/html
global.asa
script language=vbscript runat=server
SUB Application_OnStart
Application.lock
’Global variables
application(filepath)=D:\网页的研究\chat\
application(userlist)=
application(userhtml)=
application(usercount)=0
’Connections
set con=createobject(adodb.connection)
con.open wwwchat.dbf
set application(wwwchat)=con
set con=nothing
’For actions
dim action(1,200),actionsize,actioncount,actionselect
actionselect=
actionsize=200
actioncount=0
con=application(wwwchat)
set rec=createobject(ADODB.recordset)
rec.open select * from application(filepath)chataction.dbf,co
n
do until rec.EOF
if actioncount=actionsize then
exit do
end if
actionname=trim(rec(action))
actionmeaning=trim(rec(meaning))
actionselect=actionselectoption value=chr(34)actionnamechr(3
4)replace(actionmeaning,#,(对象))/option
actioncount=actioncount+1
action(0,actioncount)=actionname
action(1,actioncount)=actionmeaning
rec.MoveNext
loop
rec.close
set rec=nothing
set con=nothing
application(action)=action
application(actioncount)=actioncount
application(actionselect)=actionselect
Application.unlock
END SUB
SUB Application_OnEnd
Application.lock
set application(alinks)=nothing
set application(linktoaa)=nothing
Application.unlock
END SUB
/script
chat.asp
% @ language=vbscript %
html
head
title聊天室/title
script language=javascript
function kp() {
if (event.keyCode==13) e(0)&#59;
function ref() {
if (event.shiftKey==1  event.ctrlKey==1  event.altKey==1) {
see.location=http://118.118.118.45/vclass/seeinfo.asp?lastcount=0
ip=1&#59;}
else {
&#59;
/script
function e(way)
if way=3 then
talk.document.location=about:blank
call ref
exit function
end if
if way=1 then
cc.obj.value=
cc.words.value=我走了......
end if
n1=replace(replace(replace(replace(cc.obj.value,%,%25),#,%23),
,%26),?,%3F)
n2=replace(replace(replace(replace(cc.words.value,%,%25),#,%23
),,%26),?,%3F)
cc.words.value=
a=http://118.118.118.45/vclass/send.asp?obj=n1words=n2name=
replace(replace(replace(replace(cc.name.value,%,%25),#,%23),
,%26),?,%3F)
parent.sendwords.location=a
end function
/script
/head
body background=backchat.jpg leftmargin=0
table width=100% height=100% style=font-size:%=request.form(fs)%
tr
td height=20 align=centerfont color=#FF0000% =request.form(n
ame)% 欢迎您光临 a href=http://118.118.118.45/vclass/default.htm
target=_blank onMouseOver=’status=前往 高一(1)班’ onMouseOut=’statu
s=’高一(1)班/a 聊天室/font/td
/tr
tr
td height=*
iframe name=talk src=about:blank width=100% height=100%
/iframe
/td
tr
td height=20 valign=bottom
form name=’cc’
input type=’hidden’ name=name value=’% =request.form(name) %
p align=center说话对象:input type=text size=5 style=font-
size:%=request.form(fs)% name=obj value=% =request.form(obj)
请说话:input type=text size=32 style=font-size: %=request.form
(fs)% name=words onKeyPress=’kp()&#59;’
input type=button onclick=e(0) name=B1 style=font-size: %
=request.form(fs)% value=发送 default
input type=button name=B2 onclick=e(1) value=离开 style=
font-size: %=request.form(fs)%
input type=button name=B2 onclick=e(3) value=刷新 style=
a href=action.htm target=_blank onMouseOver=’status=特殊语言
使用说明’ onMouseOut=’status=’特殊语言/a
/p
/form
/td
/tr
/table
b=http://118.118.118.45/vclass/seeinfo.asp?lastcount=0
parent.refresh.location=b
cc.words.focus
/script
/body
/html
chatmg.asp
%@language=vbscript%
if request.querystring(pw)=g11chat then
if request.querystring(action)=clear then
application.lock
application.unlock
response.write OK!
end if
end if
seeinfo.asp
% Response.Expires=0 %
html
head
function mclick(st) {
if (event.altKey==1
parent.uif.document.cc.obj.value!=) {
parent.uif.document.cc.obj.value=st+、+parent.uif.document.cc.
obj.value&#59;
return 0&#59;
parent.uif.document.cc.obj.value=st&#59;
function c(ct) {
location=seeinfo.asp?lastcount=+ct&#59;
/script
function mover(ob)
ob.style.background=blue
ob.style.color=red
end function
function mout(ob)
ob.style.color=
end function
function mclic1k(st)
end function
/script
/head
body bgcolor=#ffffff onError=
’Get paraments
dim lastcount,ipable
lastcount=request.querystring(lastcount)+0
ipable=request.querystring(ip)+0
response.write !--lastcount--
’Creat connection
set con=application(wwwchat)
set rec=createobject(adodb.recordset)
if lastcount=0 then
if ipable1 then
rec.open select * from application(filepath)wwwchat where va
l(id)recc()-10,con
else
l(id)recc()-200,con
end if
else
l(id)lastcount,con
end if
’Seek records
dim j,lastid,thisid
j=
response.write script language=vbscript
parent.uif.talk.document.write font face=宋体
do until rec.EOF
infoname=rtrim(rec(name).value)
infowords=rtrim(rec(info).value)
if ipable=1 then response.write parent.uif.talk.document.write c
hr(34)rtrim(rec(ip))chr(34)chr(13)
mess=font color=blueinfoname/fontinfowords
parent.uif.talk.document.write % =replace(mess,chr(34),)
j=rec(id)
rec.movenext
loop
rec.close
set con=nothing
response.write /script
response.write !--j--
if j then %
parent.uif.talk.scroll(0,65000)&#59;
parent.uif.talk.document.write(/font)&#59;
/script
else
j=lastcount
end if
setTimeout(c(% =trim(j) %)&#59;,3000)&#59;
/script
center用户列表/center
hr
table width=100% align=center style=cursor:hand
trtd onMouseover=’mover(this)’ onMouseOut=’mout(this)’ onClick=’mcl
ick(所有人)’
(所有人)
/td/tr
=application(userhtml)
/table
hr
center共font color=red%=application(usercount)%/font人
b
rfont color=blue按住Alt可复选/font/center
/body
/html
send.asp
% @ language=vbscript%
%response.expires=0%
function relist
dim nl,nlen,startp,c,nh
response.write inlist:application(userlist)
nl=application(userlist)
nlen=len(nl)
startp=1
c=0
nh=
do while startpnlen
le=instr(startp,nl,)
ri=instr(startp,nl,)
if le0 and lenlen and rile and ri=nlen then
ss=replace(mid(nl,le+1,ri-le-1),chr(34),)
nh=nhtrtd onMouseover=’mover(this)’ onMouseOut=’mout(this)’
onClick=’mclick(chr(34)  replace(ss,chr(34),(引号))  chr(34))
nh=nhss/td/trchr(13)chr(10)
’response.write one!nh
chr(34)chr(34)chr(34)
c=c+1
else
exit do
end if
startp=ri+1
loop
application.lock
application(userhtml)=nh
application(usercount)=c
’response.write nhaa
end function
html
’Send message
dim obj,name,words,iname
obj=trim(request.querystring(obj))
if obj= then obj=所有人
name=replace(replace(replace(trim(request.querystring(name)),&#59;,;
words=replace(replace(replace(trim(request.querystring(words)),&#59;,
byebye=trim(request.querystring(go))
joinin=trim(request.querystring(joinin))
iname=replace(replace(name,,),,)
if joinin=1 and instr(application(userlist),iname)0 then
response.end
end if
if byebye=1 then
application.lock
application(userlist)=replace(application(userlist),iname
application.unlock
call relist
else
if instr(application(userlist),iname)=0 then
application.lock
application(userlist)=application(userlist)iname
application.unlock
call relist
end if
end if
set com=createobject(adodb.command)
com.activeconnection=con
response.write send this time
dim n1,n2,sd,ad
n1=name
n2=obj
n2=对font color=bluen2/font说:words
action=application(action)
actioncount=application(actioncount)
for ai=1 to actioncount
if action(0,ai)=words then
words=font color=redaction(1,ai)/font
for i=1 to len(words)
c=right(left(words,i),1)
if c=# then
words=left(words,i-1)font color=blueobj/fontrigh
t(words,len(words)-i)
exit for
end if
next
n2=:words
end if
next
com.commandtext=INSERT INTO wwwchat (name,info,ip,id) VALUES (?,?,?,a
llt(str(recc()+1)))
com.Parameters.Append com.CreateParameter(name,200, ,255 )
com.Parameters.Append com.CreateParameter(info,200, ,255 )
com.Parameters.Append com.CreateParameter(ip,200, ,255 )
com(name) = n1
com(info) = n2
com(ip)=request.servervariables(remote_addr)
com.execute
set con=nothing %
/html
uif.asp
html
head
title聊天室/title
function kp() {
function ref() {
parent.refresh.location=seeinfo.asp?lastcount=0&ip=1;}
else {
parent.refresh.location=seeinfo.asp?lastcount=0&#59;
/script
function aclick
cc.words.value=cc.action(cc.action.selectedindex).value
end function
function bye()
parent.refresh.location=about:blank
parent.sendwords.location=send.asp?go=1obj=所有人words=我走了......
name=replace(replace(replace(replace(cc.name.value,%,%25),#,
%23),,%26),?,%3F)
alert 欢迎希望您下次再来!
end function
function e(way)
if way=3 then
call ref
exit function
end if
if way=1 then
parent.location=http://118.118.118.45/chat
exit function
end if
,%26),?,%3F)
),,%26),?,%3F)
cc.words.value=
a=send.asp?obj=n1words=n2name=replace(replace(replace(rep
lace(cc.name.value,%,%25),#,%23),,%26),?,%3F)
end function
/script
/head
body background=backchat.jpg leftmargin=0 topmargin=0 rightmargin=0
bottommargin=0 onUnload=bye()
table width=100% height=100% style=font-size:9pt
tr
td height=*
/iframe
/td
tr
form name=’cc’
您是font color=#FF0000% =request.form(name)%/font
input type=’hidden’ name=name value=’% =request.form(name) %’
说话对象:input type=text size=70 style=font-size:9pt name=obj
value=% =request.form(obj) %
动作选择:select name=action style=color:blue&#59;font-size:9pt onChang
e=aclick()
%=application(actionselect)%
/select
请输入话:input type=text size=70 style=font-size: 9pt name=wo
input type=button onclick=e(0) name=B1 style=font-size: 9p
t value=发送 default
font-size: 9pt
font-size: 9pt
/p
/form
/td
/tr
/table
call first
function first
parent.sendwords.location=send.asp?joinin=1obj=所有人words=我来了..
....name=replace(replace(replace(replace(cc.name.value,%,%25),
#,%23),,%26),?,%3F)
b=seeinfo.asp?lastcount=0
cc.words.focus
end function
/script
/body
/html
userlist.asp
html
head
function mover(ob)
end function
function mout(ob)
end function
function mclick(st)
alert 只有在加入聊天时,才能进行用户选择!
end function
/script
/head
setTimeout(location.reload(),3000)&#59;
/script
if application(usercount)0 then
center用户列表/center
hr
/table
hr
center共font color=red%=application(usercount)%/font人/cent
er
else
trtd align=center valign=center
font size=4 face=隶书 color=bluecenter我们等待着您的光临/center
/font
/td/tr
/table
end if
/body
/html
